Viewsonic 19" LCD VA1912w problem
  • aniesns
    I have Viewsonic 19" LCD VA1912w (I think its similar to ACER AL1916wc) it contain inverter board DAC-12M030.
    When I switch on the monitor the green LED turn on for 3 seconds and than turn off. After 2 seconds it turn on again for 3 second and off again (3 second on 2 seconds off, repeat all the time).
    I replaced all the electrolytic capacitors with new ones.
    But it still not working fine and continue to turn on and off.
    Thanks,
    aniesns
  • Solder Boy
    • Nov 2006
    • 178
    Re: Viewsonic 19" LCD VA1912w problem
    You probably have failed CCL transistors on the inverter board. Also you might wanna resolder all the pins on the transformer. Additionally there should be a tiny fuse on the board... Pictures would be of great help so some of the senior members can help you out better.
    www.bcrelectronics.ca
    • Radio Fox
      • Jan 2010
      • 281
      @aniesns...there is a section dedicated to troubleshooting computer displays.
      You will get more help if you post in there.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • aniesns
        Thanks all.
        I'll try to get new FET's for the inverter.
        Aniesns
