Viewsonic 19" LCD VA1912w problem
  • aniesns
    I have Viewsonic 19" LCD VA1912w (I think its similar to ACER AL1916wc) it contain inverter board DAC-12M030.
    When I switch on the monitor the green LED turn on for 3 seconds and than turn off. After 2 seconds it turn on again for 3 second and off again (3 second on 2 seconds off, repeat all the time).
    I replaced all the electrolytic capacitors with new ones.
    But it still not working fine and continue to turn on and off.
    Thanks,
    aniesns
  • Solder Boy
    • Nov 2006
    • 178
    Re: Viewsonic 19" LCD VA1912w problem
    You probably have failed CCL transistors on the inverter board. Also you might wanna resolder all the pins on the transformer. Additionally there should be a tiny fuse on the board... Pictures would be of great help so some of the senior members can help you out better.
    www.bcrelectronics.ca
    • Radio Fox
      • Jan 2010
      • 281
      @aniesns...there is a section dedicated to troubleshooting computer displays.
      You will get more help if you post in there.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • aniesns
        Thanks all.
        I'll try to get new FET's for the inverter.
        Aniesns
        • Returning Buick
          Viewsonic G810 vertical deflection problem
          by Returning Buick
          I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
          04-01-2025, 07:57 PM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • lostone
          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
          by lostone
          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
          05-19-2024, 11:40 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
