Asus vg248qe purple light problem
  • Rennokas
    • Apr 2013
    • 20
    • Estonia
    Re: Asus vg248qe purple light problem
    Originally posted by lotas
    What is the voltage across these chokes?
    And what is the resistance between gnd. If the capacitor is short-circuited, the dc-dc converter U402 could burn out.
    0.91v between the chokes. Right ones resistance is 144 ohm and left one 0.4 ohm.
    • lotas
      • Jan 2016
      • 4819
      • Russia
      0.4 Ohm is a short circuit, unsolder these two capacitors, which I soldered to the board and re-measure the resistance on the left choke
      • lotas
        • Jan 2016
        • 4819
        • Russia
        And you need to measure the voltage at each choke relative to gnd, and not between them
        • Rennokas
          • Apr 2013
          • 20
          • Estonia
          Which caps do you mean?
          • lotas
            • Jan 2016
            • 4819
            • Russia
            these
            • Rennokas
              • Apr 2013
              • 20
              • Estonia
              #26
              Voltage between GND
              L406 has 1.23v and 1.21v
              L407 has 0.21v and 0.29v
              Resistance
              L406 has 300ohm and 300ohm
              L407 has 1ohm and 1ohm
              Removed the two caps and measured
              L406 has 137ohm and 137ohm
              L406 has 0.94v and 1.2v
              L407 has 0.08v and 0.2v
              • lotas
                • Jan 2016
                • 4819
                • Russia
                #27
                On the L407 - 1 Om, this is very small (short circuit) on this bus, there are two options, either the U402 MP2125 microcircuit itself burned out or something that sits on this bus ceramic capacitors ...
                It is necessary to unsolder the choke L407 and check the resistance at both points relative to ground.
                • Rennokas
                  • Apr 2013
                  • 20
                  • Estonia
                  #28
                  Took off L407 and resistance relative to ground from upper choke 0.3 ohm and bottom choke has 220 ohm
                  • Rennokas
                    • Apr 2013
                    • 20
                    • Estonia
                    #29
                    Not easy to get the MP2125 ( https://www.monolithicpower.com/en/mp2125.html )
                    Any alternative which would fit?
                    • usamy
                      • Mar 2021
                      • Italia
                      #30
                      hi gentlemen, I can't open a new post because I'm new. I have my asus vw246h that to make it turn on I always have to unplug. I changed all the electrolytics on the power supply board but nothing.
                      • gamartinelli
                        Asus VG248QE won't power on / purple light
                        by gamartinelli
                        I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
                        09-29-2022, 04:15 PM
                      • lazaro.089
                        Asus Zephyrus M16 / GU603ZW problem
                        by lazaro.089
                        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                        CPU: Core i9-12900H
                        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                        08-26-2025, 06:33 PM
                      • AtelierRepa
                        ASUS X712JA problem
                        by AtelierRepa
                        I have a problem with the bios, let me explain.
                        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                        06-15-2024, 04:33 AM
                      • greg1985
                        Asus dabkxmb18b0 rev.b bios problem
                        by greg1985
                        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
                        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
                        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
                        10-20-2025, 11:34 AM
                      • boticario
                        problem with asus tuf A17 FA707NUR
                        by boticario
                        I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
                        The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
                        After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
                        I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
                        10-18-2025, 04:37 PM
