Asus vg248qe purple light problem
  • Rennokas
    • Apr 2013
    • 20
    • Estonia
    Re: Asus vg248qe purple light problem
    Originally posted by lotas
    What is the voltage across these chokes?
    And what is the resistance between gnd. If the capacitor is short-circuited, the dc-dc converter U402 could burn out.
    0.91v between the chokes. Right ones resistance is 144 ohm and left one 0.4 ohm.
    • lotas
      • Jan 2016
      • 4575
      • Russia
      0.4 Ohm is a short circuit, unsolder these two capacitors, which I soldered to the board and re-measure the resistance on the left choke
      • lotas
        • Jan 2016
        • 4575
        • Russia
        And you need to measure the voltage at each choke relative to gnd, and not between them
        • Rennokas
          • Apr 2013
          • 20
          • Estonia
          Which caps do you mean?
          • lotas
            • Jan 2016
            • 4575
            • Russia
            these
            • Rennokas
              • Apr 2013
              • 20
              • Estonia
              #26
              Voltage between GND
              L406 has 1.23v and 1.21v
              L407 has 0.21v and 0.29v
              Resistance
              L406 has 300ohm and 300ohm
              L407 has 1ohm and 1ohm
              Removed the two caps and measured
              L406 has 137ohm and 137ohm
              L406 has 0.94v and 1.2v
              L407 has 0.08v and 0.2v
              • lotas
                • Jan 2016
                • 4575
                • Russia
                #27
                On the L407 - 1 Om, this is very small (short circuit) on this bus, there are two options, either the U402 MP2125 microcircuit itself burned out or something that sits on this bus ceramic capacitors ...
                It is necessary to unsolder the choke L407 and check the resistance at both points relative to ground.
                • Rennokas
                  • Apr 2013
                  • 20
                  • Estonia
                  #28
                  Took off L407 and resistance relative to ground from upper choke 0.3 ohm and bottom choke has 220 ohm
                  • Rennokas
                    • Apr 2013
                    • 20
                    • Estonia
                    #29
                    Not easy to get the MP2125 ( https://www.monolithicpower.com/en/mp2125.html )
                    Any alternative which would fit?
                    • usamy
                      • Mar 2021
                      • Italia
                      #30
                      hi gentlemen, I can't open a new post because I'm new. I have my asus vw246h that to make it turn on I always have to unplug. I changed all the electrolytics on the power supply board but nothing.
                      • gamartinelli
                        Asus VG248QE won't power on / purple light
                        by gamartinelli
                        I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
                        09-29-2022, 04:15 PM
                      • AtelierRepa
                        ASUS X712JA problem
                        by AtelierRepa
                        I have a problem with the bios, let me explain.
                        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                        06-15-2024, 04:33 AM
                      • Dobrowol
                        Asus GA402RK keyboard and kb backlight problem
                        by Dobrowol
                        Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                        04-28-2025, 04:30 PM
                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-07-2024, 02:50 AM
                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
