Re: Gateway FPD2185W
Yes pin 1 of the controller chip is shown on the top left in the picture in the first post of this thread.
Gateway FPD2185W
The U303 controller chip is a BIT3193G. Curt Palme mentioned ordering some in this thread: https://www.badcaps.net/forum/showthread.php?t=10364
No word on success or failure though (I asked!).
PlainBillLeave a comment:
The thought crossed my mind to change them. I did a resistance check and here is what i found:
Transistor G – D D – S G – S
U301 (AOD405) 365k 360k 4.7k
U302 (AOD408) .77M 380k 347k
u304 (AOD405) 368k 364k 4.7k
u305 (AOD408) .75M 379k 346k
So I would say that they are not shorted, but could still be not working properly. And I could maybe see how this would cause lower power output to the CCFL transformers. For the cost, I might as well replace them since am in this far already. Unfortunately Digikey is showing a lead time of over a month to get the AOD417 (AOD405 replacement) back in stock
Anyone else have any ideas? PlainBill?
Edit: I may have some extras here, let me look around.Leave a comment:
No word on success or failure though (I asked!).Leave a comment:
Also what should the resistance on the transformers be?
On the big ones I get ~.6 ohm across the primaries and ~154 ohms across the secondaries. Could this be a short on the primary side? There is not much between the transistors and the primary windings, just a couple smd capacitors (c314, c315, and c317) and those don't show a short across them.
The small transformers all show ~0.6ohm on the primary and ~220ohms on the secondary.
My next move might be to take a set of lamps out of another panel and solder the leads for them directly to the board. Then see if I still get 2 seconds to black.Leave a comment:
Let's start at the controller and see if we can isolate the cause of the problem. What is the part number of U303, the inverter controller? I seem to remember that locating a datasheet was a sticking point on another one of these designs.
Also, if ANYONE has come across a schematic or service manual for this monitor, I would appreciate knowing about it. Even a service manual or schematic for any monitor using the small transformers would help me.
Anyone else have any ideas? PlainBill?Leave a comment:
I finally got around to replacing the lamps in my FPD2185. Unfortunately, after painstakingly wiring up the new lamps, I am still having a two seconds to black problem. I tried re-soldering the joints around the two big and the six little transformers (also checked resistance) over to the ccfl connectors to no avail. The problem seems to be one of 'insufficient voltage' to the ccfls. Sometimes two of the lamps on a side light, sometimes only one. When it is two lit, the center one it out on both sides. And a couple times the center one came on, but only by itself. Any ideas on how to proceed?Leave a comment:
Well great news for me, it works perfectly. This was the best of 7 dead monitors I picked up for free. It looks brand new, still has the stickers on the front bezel.
I finished re-assembling it today, still don't have a power cable so I 'gator clipped power to it, and it fired right up. This really is a nice monitor. Well worth the $5.00 (approx) worth of capsWould be interesting to get the total on-time out of it, anyone know if that's available in a service menu?
I finally cracked open the one I have on my pile. 7 of the 8 classic 470 25s were bulged and some leaking, and 1 of the 3 470 16s on the main board was bulging. Replaced 'em all, and 2 others in the inverter section.
I have never tested it, I don't have a power cable at the moment.
Just for fun, measured a one of the 470s, 33uf and 9 ohms esr.
Will try to test soon.Leave a comment:
You will need the following caps for the powersupply:
(all listed are Panasonic FC) followed by Digikey part number
8x 470uf 25v P10275-ND
2x 220uf 25v P10271-ND
1x 47uf 25v P10267-ND
1x 10uf 50v P10316-ND
For the display board:
3x 470uf 16v P10247-ND
Just hope you don't have bad lamps too!Leave a comment:
Originally posted by soul12.0i got the same moniter i got 6 of the main power caps bulged and one bulged on the screen controler
any help would be great
A first step would be to list the capacitance, voltage, diameter and height of every capacitor on the boards. Someone will then suggest replacements (The diameter and height are only required for those caps with limited clearance).
Have a read over
https://www.badcaps.net/forum/showthread.php?p=92533
that will help you choose and order caps.
any help would be greatLeave a comment:
I ordered them all together. What I did was send them an email (sales@ccflwarehouse.com) and explain the pricing from eBay combined with some of their items from their website. For instance, $8 per CCFL (460mm x 2.6mm), white return wire ($1 per foot, but you should be able to re-use most of the original wiring), etc. They also advertise $4.99 flat rate shipping. I asked them to send me an invoice through Paypal, and they did within an hour. I actually didn't ask for the triple end caps, they included them at no cost... One other thing that I ordered was some 1/2 inch kapton tape to hold the spliced/soldered return wires in place, I think it was like $1.75 for a 6 inch strip. Next time I'm just going to order a roll! Good luck and let us know how it goes!
Edit: I see you're from IL... whereabouts? My wife and I moved from Schaumburg around 6 years ago.Leave a comment:
Well wishful thinking did not prevail here. The re-cap was not successful. The monitor is still doing the two seconds to black routine. I took apart the panel and found some of the ccfls with the LV wires nearly burned off and black bands at the ends of the ccfl tubes. So I guess I am looking at a total lamp replacement on this one. Wrog, do you remember what the out the door price was for the lamps and all assorted wiring/end caps? I found the lamp you mentioned on ebay from ccfl warehouse. Did you order the end caps/wiring seperately? Or did they allow you to do it all in one order/shipment? I also did not see the triple end cap on their website, only a single.Leave a comment:
I just got a another one of these from a colleague to work on. Only two of the 470uf caps are bulged. None of the 4 driver transistors are burnt/shorted. The symptoms were that the monitor was shutting down after a short time. I went ahead and ordered all 12 caps for the power supply. I just hope its not the CCFLs.Leave a comment:
Guys,
Replaced 8- 470ufd,25V(SAMXON) with XICON Caps and that was it.Cost of STARBUCKS Venti and hour of Soldering and Desoldering.By the way XICON Caps can be procured at ALL Electronics (excellent source of surplus).
KrubilLeave a comment:
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
Channel: Schematic Requests ONLY!
04-25-2025, 07:01 AM -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Channel: BIOS Requests ONLY!
Gateway ID49C04u ID49C11u Laptop Schematic...
Channel: Schematics and Boardviews
11-01-2024, 06:46 AM -
Gateway NV53 Series Laptop Schematic
Wistron SJV50-TR 09228-1 48.4FM01.011 Rev 1M...-
11-01-2024, 02:54 AM -
- Loading...
