OSD pops up, LG Flatron W2361v
+ More Options
Posts
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Re: OSD pops up, LG Flatron W2361v
    I gave up on this project afterall. Too much time and space for an old monitor so I donated it for cctv monitoring. Thank you all for the suggestions and tips though. Still learning even without successes
    • electrophoros
      LG Flatron W2361V PSU Troubleshooting
      by electrophoros
      Hi everyone.
      I am trying to troubleshoot this computer screen which went black and won't power on after a power surge.
      I have measured the output voltages and there seems to be proper voltage pressence on the 5V outputs, there is no voltage on the 22V outputs and I am unsure of what I should be measuring on ADIM, BDIM, EN and OLP.
      There also doesn't seem to be any voltage on the backpanel outputs:
      I have already identified and replaced two bulging electrolytic capacitors, and there is voltage after the fuse.
      07-27-2022, 07:37 PM
    • Bitvive
      LG Flatron starts w. coil whine and power issues
      by Bitvive
      Hi ,
      My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
      Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
      So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
      During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...
      08-18-2024, 06:34 PM
    • conrado.g
      LG Flatron W2353V no power on, nothing.
      by conrado.g
      Hi folks,
      This is my first post. Richard over at YT Learn Electronics Repair recommended this forum in one of his videos. I am learning electronic repair now in my thirties.
      I have an LG Flatron W2353V that doesn't power on. It just stopped working from one day to the next. No lights, no nothing, and I don't know how to test the keypad since it doesn't have buttons, just a touch keypad. I took out the power supply board, and am attaching pictures. Some of the capacitors are bulged. I have a multimeter and have tested voltage at several places:
      Capacitors:...
      06-01-2023, 09:07 AM
    • usyusy
      Dell Iris HSW/BDW 14216-1 not triggering
      by usyusy
      Dell Iris HSW/BDW 14216-1 PWB: 1XVKN REV: A00
      Not triggering, any guide
      05-07-2023, 08:33 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
