Dell 19" SE198WFPf SE200WFPf
  • no1knows
    • Sep 2009
    • 9
    I had luck fixing a Dell 19" wide (SE198WFPf SE200WFPf) using the following info from another thread: https://www.badcaps.net/forum/showth...highlight=R852
    Unit had no power up at all.
    Metria:
    "Re: Dell E173FPf
    I have one of these monitors with no power led as well. Trouble shooting led me to find that R852 a .2 Ohm resistor is open, and after removing Q850 and testing it with a meter, no matter what pins I go between I get no more than 1.5 Ohms of resistance. Also my shorts on the Circuit board seem to have gone away. I have ordered another AP2761-A on Ebay, and will let you know if repacing it and this Mosfet fix my issue
    The units must use the same power supply. I replaced R852 and Q850 and It works fine now. I had shorts between all three pins on Q850. I burned out R852 twice before I replaced Q850.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
  • OntarioTL
    Dell 5410 greyed out BT
    by OntarioTL
    Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
    If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
    Dell Lattitude 5410
    Service Tag...
    Yesterday, 01:28 PM
  • lalle-
    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
    by lalle-
    Hello!
    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
    08-11-2024, 02:01 PM
