Acer_1914....Oh,BTW Greetings..
    time we all met,...been studying almost all posts, and ..some items match
    presumptive faults and have also studied the pics,...the REV on my board
    is: 1J,..board nu:433AAP30021..for the PWR/INV..
    2 items, if you please;
    1. identify U801 (wiped nu out)..and,
    2. my Monitor flashes grn LED,..as soon as plugged in..
    have put bright lite near screen,..noticed that the screen flashed dimly,..
    in btwn flashes,...almost as in oscillation,...caps appear normal....
    and no overly suspicious overheating...am only now trying to identify
    chips on board..and study function bfor repairing...(don't want to..
    ..make things worse)..
    unable at this time to post pics...no cam set yet,...am using security vcr
    to tape repair procedure...see why puff the magic smoke,...
    camthru lighted magnifier,...monitored on screen....and taped
    might be helpful to some 1 out there....
    also notice dark spot at top of thermister (RT801 on board)..but saw
    no posts on this,...any prob there?....
    any points as to how to proceed?...TYVM..in advance..
    Re: Acer_1914....Oh,BTW Greetings..
    If the caps appear normal, check the inverter driver transistors for shorts.
    PlainBill
    P.S. This isn't twitter. Use as many characters as you need. No need to shrink every thing down as short as possible. Clarity is important, brevity isn't.
    pb
      I agree. This can be a reference doc in the future and complete sentences (in fact, complete words...) would be appreciated.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        Twitter and their character limit.
        If you can describe your ideas in 140 characters or less you don't have any ideas .
          • GeForce GT1050
            ALMOST correct. You just did! And very well.
            PlainBill
              we try again,... : )...
              OK...got the point...only abbriviate as my typing is lousy...
              now, in reference to my previous post,...can anyone help to id the chip
              listed as U801 on the solder side of the pwr/inverter board for an Acer AL1914?
              and, it's clear that the fault description was less than adequate,...so
              once the Monitor is plugged in,..the green power lamp flashes,..but I have noticed when I shine a bright light on the screen,...there is a dim flash
              of the screen,..which seems to oscillate in this fashion:
              power led flash,..screen flash (very dimly) about 1hz/sec..
              also,..would like to know if the thermister (RT801 on the same board),..
              which has a dark spot at the top could be part of problem?
              as I've said,..caps appear normal and no obvious overheating..
              hoping this is a bit clearer than my last post, and again all feedback
              is appreciated...thanks again in advance
                Re: we try again,... : )...
                What caps (brand/series)?
                Pics would help you a lot. The bigger, the better
                • GeForce GT1050
                  just to say I am in process of setting up camera
                  will post pic at that time thanks,....
                    hello again,...please be patient with me, as uploading pics is new to me
                    I have included a sample pic showing Thermister RT-801 (hopefully)
                    this,along with my previous posting should give a fair idea of what
                    I and apparently others here are dealing with..
                    any criticism regarding pic welcome, as well as any hints
                    spinning as par for course
                    https://www.badcaps.net/forum/attach...id=13791&stc=1
                      https://www.badcaps.net/forum/showthread.php?t=1868
                      PlainBill
