Viewsonic VX2235WM-3 problems
  • skelband
    • Feb 2020
    • 6
    I am trying to diagnose an issue with the above monitor.
    Initially, I assumed that it was a PSU issue, but I'm not so sure.
    OK, here are the symptoms:
    Powering on the monitor, the backlight comes on, but there is no display on the panel. The power light is illuminated Blue.
    After about 3 seconds, the backlight goes off and the the power light goes Amber.
    I cannot get it to do anything with the buttons with either the blue or amber lights illuminated.
    If I plug in a VGA source, then the panel stays on indefinitely, blue light + backlight.
    I can manipulate the power LED and backlight status by plugging the VGA connection in and out so it is not completely dead and is reacting to stimulus.
    So, it sounded like the classic issue, power on, then to black after a few seconds which suggests PSU voltage issues.
    I downloaded a service manual and had a look at the schematics etc
    I have checked voltages with a meter from the PSU and there is 5V output to the logic board. The PSU is also generating 24V measured at the L803 link, although the logic board does not seem to require it.
    I measured the outputs of the 3.3V and 1.8V regulators on the logic board and it seems good.
    I put an analogue scope on all the voltages and they seem nice and steady, not flapping around all over the place.
    Since the RTD2553V LCD controller seems to be doing something (maybe, the display does not go off when I plug in an active VGA connection to a running PC), I can only assume that there is something amiss with the microcontroller.
    And this is where I start to flounder somewhat.
    Any ideas where I should look now? I did see something about EPROM going bad somewhere but couldn't find any details.
    I will post some board pictures.
  • skelband
    • Feb 2020
    • 6
    Re: Viewsonic VX2235WM-3 problems
    I also check the reset signal on the logic board. Jumps up briefly on power, drops to ground quickly after. Cap/diodes seem good.
    If people think that there is still some merit in recapping the PSU (perhaps the levels are not as stable as my old analog scope seems to think) I am happy to do that and come back to it. There is no obvious cap deterioration although of course there isn't always a physical sign.
    Also, confirmed that pin 9 of the power cable bound for the main logic board, at the PSU side, is not connected. It carries the 24V power, so that confirms that it is not required for the logic board.
    • R_J
      • 9567
      Since you have a scope, check if you have video signals on the lvds cable going to the panel, also check if you have +5v going to the panel (P104 pins 28,29,30). Q103 is the mosfet that controls the panel voltage, Source is +5v Drain connects to the panel.
      You need to have signal going to the monitor or it will likely go into standby.
      If the backlight is working and stays on I suspect the power supply is ok.
      • skelband
        • Feb 2020
        • 6
        Thanks for the suggestions.
        I can verify that 5V is present on the P104 connector and if I put a VGA signal on the VGA port from a PC, I can see activity on the LCD lines lines on that connector.
        When I look at the panel though, I only see the backlight and no display content.
        It is very strange.
        My scope is very old and not really intended for looking at this kind of thing. It looks like the signals are offset by about 1.5V but oscillating by about 0.25V. Take that with a pinch of salt however since it is well out of calibration.
        I also checked the ground connections to P104.
        • R_J
          • 9567
          The scope doesn't need to be that fancy, if you have what looks like video on the lvds and there is 5 volts, I suspect there is a problem on the t-con board, that's the board that drives the panel
          • skelband
            • Feb 2020
            • 6
            OK, that makes sense.
            I'll have to dig further into the panel to find that.
            What an interesting adventure!
            • skelband
              • Feb 2020
              • 6
              I managed to strip it enough to get to the TCON board but I couldn't find anything there. Nothing obvious. There look to be a couple of voltage regulators on there but I could not find anything amiss.
              I think I have spent more than is reasonable on this project so it is going to recycling. Thanks for the help though!
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
              • korben_dallas
                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                by korben_dallas
                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                MY QUESTION:
                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                02-14-2024, 12:23 AM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
              • Hondaman
                USB problems?
                by Hondaman
                Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                08-12-2024, 03:26 PM
