Philips TV/LCD 15PF5120 "No Signal" using DVI-I
  • Kevin O'Henly
    Ontario Member
    • May 2009
    • 48
    I have a philips model: 15PF5120 showing a "No Signal" condition when connected to a PC using the DVI-I cable input.
    No bad cap.s this time. All the electronics checked out 100%.
    To understand the problem I had to understand DVI. Judging from the blog community, I am not the only one that needed some assistance in this area.
    If you need a DVI primer then checkout:
    http://en.wikipedia.org/wiki/Digital...rface#Overview
    and:
    http://www.playtool.com/pages/dvicompat/dvi.html
    The second link has pictures of the various cable plugs and specific info. for ATI CATALIST driver users. ...very useful.
    The DVI interface caries digital and analogue (VGA) signals to the monitor from the video card in the PC or MAC. To resolve which signals the video card sends to the monitor (analogue or digital) the video card requests an EDID from the monitor on the digital chanel. If there is no EDID returned the video card then the video card logic assumes the monitor is a TV.
    The "no signal" problem with this TV/LCD in my case was due to my use of a VGA cable with a VGA to DVI adapter on the end. The VGA to DVI adapter cable has no digital channel for identifing the video mode EDID of the Philips TV/LCD and assumed it was a TV.
    When I set up the catalist control center that the TV/LCD was an LCD monitor then the proper analog (VGA) signals were provided and the monitor worked fine.
    Other DVI problems include:
    ~ using the improper cable. The DVI-D cable does not have the four pins that carry the analogue signals while the DVI-I cable has both the digital (SINGLE OR DUAL digital) AND ANALOGUE (vga) signals.
    ~ setting the video card resolution higher than the monitor.
    My take home lesson was the DVI interface involves matching the cable, monitor, video card, video drivers and video driver setup to get good results.
    rgs,
    Kevin
    Be yourself,
    everyone else is taken.
    by momaka
    03-15-2023, 10:17 PM
  • logocar3
    Philips 288P6LJEB/27 monitor PSU outputting 8V instead of 12V
    by logocar3
    I am having problem with fixing Philips 288P6LJEB/27 monitor PSU, board number 715G6457-P01-000-0010.
    Data:
    - Schematic is attached to post
    - Photos can be found on flicker: https://www.flickr.com/photos/198547898@N03
    Problem:
    - PSU board have power outputs at 5.2V, 12V and 24V - board is correctly outputting only 5.2V (correct), and not 12V (without load only 8.16V) or 24V (without load 0V)
    State of PCB / monitor:
    - Bought defect monitor from a company auction
    - There were some attempts to fix...
    06-19-2023, 11:40 PM
  • Schwoin
    Philips 243v5lhsb00 Monitor Picture too bright
    by Schwoin
    Hey everyone,
    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
    you can see them on the top half of the photo.
    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
    03-21-2023, 12:40 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
