Dell E171FPb pic
  • elbtax
    • Apr 2008
    • 59
    Dell E171FPb pic
    Any ideas what may cause the display to look like this? The osd does not work. No picture whatsoever.
    Thanks in advance...
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
  • lalle-
    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
    by lalle-
    Hello!
    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
    08-11-2024, 02:01 PM
