AOC E970SW no backlight
  • Sraros
    • Jan 2017
    • 223
    • Greece
    I have this monitor which has backlight issues.
    I can see image with flashlight, but the LEDS don't turn on.
    The LED bar is working fine because when I unplug the monitor they flash altogether, every single one of them.
    I don't have voltage on the output of the LED bar connector (with or without the bar connected) but I have 18,3V on the PSU to main cables.
    The image on the panel works fine. Any ideas?
    • 12206
    • U.S.
    Re: AOC E970SW no backlight
    Check all the diodes, easy place to start.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Some of your solder joints look cracked and need to be resoldered.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Normally if the leds flash then there is a possibility that you have one or more leds shorted.
        Check Q801 and D801. There sholuld be 15V on Pin1 of U801 and approximately 5V on Pin 5 of U801.
        It would be worth checking all the 0 ohm resistors around U801
        • Sraros
          • Jan 2017
          • 223
          • Greece
          Pin 1 is 0,35V and Pin 5 1,5V.
          All 0Ω resistances look fine and well soldered.
          I am attaching a picture just to see if I measure the correct pins
          Red arrow is pin1 yellow is Pin5
          So should I assume U801 has gone bad?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Sorry the 15V should be on Pin 9 not Pin 1 as I said above.
            Pin 5 at 1.5V seems a little low. Can you check it agai but this time at the connector CN902.
            Did you use you meter to test the 0 ohm resistors and Q801 and D801 ?
            • Sraros
              • Jan 2017
              • 223
              • Greece
              The 0Ω resistors I checked them all both in continuity and Ω. Look fine.
              Q801 is G to D and S to D 18,sth with a small voltage difference between them.
              D801 doesnt exist but I guess you mean D802 which is also ok. 18,4V with a 0,sth voltage drop.
              PIN9 on the U801 takes 18,4V, PIN 4 3V which is the DIM from the main I guess? (Goes to 0 when goes into standby) and then PIN2,5,6,7,8 all have 0V.
              CN902: Ground to white cable is 18,4, ground to black lead is 0V
              I hope I gave all info as better as possible
              • Sraros
                • Jan 2017
                • 223
                • Greece
                By the way, I made a slow motion video of how the led bad reacts sometimes when I plug off the power cable without turning off the monitor. I upload a SS if it helps. To me it seems all LEDs are flashing, but I cannot say if this really means the bar is ok :/
                Thanks for your help one more time
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  With the set off and your meter set to diode mode check Q801 and D802
                  Pin 9 at 18.4V is fine and is the Vcc supply for U801
                  What is the voltage between the pin marked ON/OFF to chassis when powered up and also on the DIM Pin.
                  Has the set only a single led bar as in post #8
                  Can you post the slow motion video you took of the leds
                  You do have some poor solder joints on the power supply that need to be resoldered.
                  • Sraros
                    • Jan 2017
                    • 223
                    • Greece
                    ON/OFF is 1,6V when on and 0V when off.
                    D802 looks fine, in diode test 316 and no connectivity in reverse.
                    In diode test:
                    Q801: red S - black G:696, opposite no connectivity
                    Black D - red S:330
                    All the rest no connectivity
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      What is the part number on Q801
                      Meter in diode mode
                      Code:
                      D - S = 0.33  and reverse leads S - D = Infinity
                      D - G =    and reverse leads D - G =
                      G - S = 0.69  and reverse leads G - S = infinity
                      What is the full board number 715Gxxxxxx
                      • Sraros
                        • Jan 2017
                        • 223
                        • Greece
                        PA110BDA
                        D - G = infinity and reverse leads D - G = infinity
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Mosfet appears to be OK.
                          Have you made good the poor solder joints around the board.
                          If you step by step your video can you see if any of the leds are not coming on or coming on later than the others
                          • Sraros
                            • Jan 2017
                            • 223
                            • Greece
                            Can you tell by the video? I think there's a flow but looks normal
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Doing a video and stepping it has worked for many people on this forum.
                              • Sraros
                                • Jan 2017
                                • 223
                                • Greece
                                It wasn’t uploaded, I had to zip it
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  You said that when you powered down the led bar would flash. That's what the video should show.
                                  Do you have an oscilloscope? It makes fault finding alot easier.
                                  • Sraros
                                    • Jan 2017
                                    • 223
                                    • Greece
                                    At the video I am unplugging the cord. The bar doesnt flash when I turn it off by the button, only when I unplug the cord while it’s ON.
                                    Oscilloscope no, I don’t have :/ I am an amateur hobbyist
                                    After the troubleshooting on the board, do you believe it’s the LED bar or the board?
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      It's hard to tell at the moment. It may well be a problem with the Led driver IC or be the result of just one led failing.
                                      Can you post the video of when you unplug the power and the led strip flashes. It does need to be well focussed on the strip.
                                      • Sraros
                                        • Jan 2017
                                        • 223
                                        • Greece
                                        Would it help to check in diode mode each LED separately?
                                        From the last video though, if I freeze it right before they go full lit, it seems they work fine
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Zilicon
                                          NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                                          by Zilicon
                                          Greetings everyone.
                                          Please I need help with the above monitor.
                                          Below is the summary of what happened and what I have done:
                                          The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                                          The backlight driver IC is 0b3350cp.
                                          I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                                          11-07-2023, 09:12 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • Salem Aboshala
                                          820-00138-A got image but no backlight
                                          by Salem Aboshala
                                          Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                          I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                          History: my laptop backlight stopped working without any reason.
                                          Symptoms:
                                          I have image on screen using my flashlight.
                                          I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                          Keyboard backlight still working and can be adjusted normally.
                                          Since two days I tried to follow all similar...
                                          06-11-2024, 03:02 PM
                                        • ajgae
                                          HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                          by ajgae
                                          Hi everyone!
                                          First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                          03-06-2025, 09:53 AM
