LG 34UM59 white “washed out” image
  • occhia
    • Jun 2017
    • 27
    • Italia
    Re: LG 34UM59 white “washed out” image
    Ok understood.. thanks a lot for the reply.
    Do you mean the “SW0686” chip, correct?
    Can I do something like this?
    https://youtu.be/eA1qsnRuS_Q
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      Sorry i've noticed now there's another chip, it's U51 i think
      • occhia
        • Jun 2017
        • 27
        • Italia
        Ok thank you, compatriot!
        So, you suggest to try reflowing the RT6811 chip with Heathgun and see what happens?
        And.. so, this is the DC-DC and gamma ic chip? I'm just asking to learn..
        Thanks!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4541
          • Italy - Milan
          I'm not really sure what it is but i think is a pmic+gamma chip, but just to be sure, on the leftmost i see those gamma testpoint named like V12,V8.. etc, check with dmm to which chip are connected.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4541
            • Italy - Milan
            take the multimeter sat in continuity (beep), then place one probe on the test point the other on one of the two chips, if it beebs theme are connected.
            • occhia
              • Jun 2017
              • 27
              • Italia
              #26
              Ok this evening I will check and post updates.
              Thanks a lot, really.
              • occhia
                • Jun 2017
                • 27
                • Italia
                #27
                Hello everyone!
                I did some testing.
                For the continuity test between those points (from V1 to V14) some of them show continuity with some pins of the RT6811 chip (marked as U51 on the board). These point are V3/4/5 and 10/11/12. The other points do not beep with no one of the pins of that chip.
                I also tried the voltages on those points and they all have tensions, decreasing gradually from about 11v to 1v (V1=11v, V2= 10.5v, V3=9.7v and so on..)
                Thanks for help.
                • occhia
                  • Jun 2017
                  • 27
                  • Italia
                  #28
                  No one has some suggestions?
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • rimwall
                    Sony KD-65x7500D - double image - Tcon or Panel?
                    by rimwall
                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                    11-18-2025, 02:09 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • jason123
                    ASUS PG27V Rolling Image - TCON?
                    by jason123
                    Hi there,
                    My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                    I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                    It does this even with the monitor not connected to a computer / graphics card....
                    11-01-2025, 05:41 PM
