Samsung S24D590PL LED partial backlight problem
  • ZackN
    • Dec 2016
    • 24
    Hello Knowledge holders.
    First off, thanks for sharing all the info here, I have fixed multiple electronics by just searching the forum and finding what I needed.
    Samsung S24D590PL model code is LS24D590PLY/ZA
    I cant seem to find this particular one though. I bought this monitor at a thriftstore ($20) and it looked decent when plugged in to power. Once home I noticed the bottom right corner was very dim.
    Upon opening it up I found that not all the LEDs are lit. Sometimes they light when first powered on but only for a moment. It is strange that it seems every other on on the right side is lit.
    I have found a replacement panel but at $307 thats out of the budget.
    This post here has a conversion kit from LCD to LED, could I potentially use something similar to replace my current LEDs?
    Again, thank you all for contributing to my ever growing electronic knowledge!
  • CapLeaker
    Leaking Member
    • 8064
    Re: Samsung S24D590PL LED partial backlight problem
    strip the panel down ( remember the order on what goes where ) and take the backlight out. Either you have to find replacement LED's and fix the strip or get replacement strip.
    • ZackN
      • Dec 2016
      • 24
      CapLeaker, thanks for the encouragement. I had it mostly stripped down but the backlight was still in it.
      I have now removed the backlight which I was surprised was only 1 led strip. It looks like 1/3 of the LEDs dont stay on. They will flash, then there will be a tiny tick from the board and then they will turn off. How can I determine if this is a LED issue or a board issue? Is the voltage supplied by one supply and divided or is it three separate transistors (is this the right name) that supply power to the strip?
      I have done some quick googling but have not turned up any replacements, just out of stock inventory from a bulgarian website.
      On the front it reads (I think)
      M2LE-236SMD-R2C132171
      94v-0 1443
      and the sticker on the back reads
      PB4009940
      236AJTS
      • ZackN
        • Dec 2016
        • 24
        It looks like I might be able to make this set work. I don't think there is room in the bezel for 2 sets of LED strips but I will see once it arrives. I should be able to find a 12v source and can just pull the control pin on the original led output. I would rather find an actual replacement strip though. I will post and update how this works so that other searching can do the same or avoid.
        https://www.amazon.com/Highlight-Dim.../dp/B00XFXM4NA
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Well, worst case scenario, maybe you'll just run one of the LED strips inside the case of the monitor if there is no room to fit it anywhere else... or extend it outside the monitor to light behind the monitor. (That is, if the LED kit board cannot run with one set of LED strips disconnected.)
          Thanks, that will be much appreciated. It's contributions like this that keep the information on these forums useful.
          As for the LED strips on Amazon... from what I've heard, those cheap LED strips (well, maybe not the particular ones in Amazon, but just in general) actually last longer than the original monitor strips sometimes. As for how the monitor will look with them, that's another question - especially in your case, if you happen not to be able to fit both LED strips in the monitor frame.
          • ZackN
            • Dec 2016
            • 24
            I am having trouble finding a proper power source for the new LED strips. It looks like they require between 9 and 30v input. The original output on the stock LED seems to be 34v.
            I was testing the original LED strip and noticed that the three sets were reading 33.8, 34, and 35V. When not plugged in to the strip the power seemed to measure about 6.6V. This confuses me, is the board regulating voltage to the strip or is something amis on the board causing the voltage to be slightly different for each set of LEDs?
            Pictures of the back and front of the board.
            Thanks all for the help, I am finding electronic repair more difficult than mechanical repair.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              The board is not regulating the voltage, but rather the current that goes to each strip. For better efficiency, this is typically achieved with PWM control... so the voltage over each LED strip is NOT a steady DC value. Therefore, you cannot really measure it accurately with a multimeter.
                09-07-2024, 05:50 AM
              • C152Heavy
                by C152Heavy
                Summary for TL-DR readers:
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • sansanpartida
                Samsung QE82Q70RAT no backlight
                by sansanpartida
                Hi everyone!
                Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                My issue: No backlight.
                Model: QE82Q70RAT
                Type No: QE82Q70RAT
                The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                So hopefully, I can fix this cheaper.
                05-22-2024, 06:56 AM
              • Xristakis795
                samsung ue55ju6800 change backlight strip
                by Xristakis795
                hi to all i want to change the backlight strip on the above model
                do you know if there is someone helpful video with similar model whith mine ?
                thanks on advance
                04-18-2023, 01:17 PM
              • Warrensmith
                Samsung BN44-00807E Low Backlight
                by Warrensmith
                Symptom is dim backlight - this set came in with almost no backlight.
                Samsung UN55JU6500FX2A
                1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                10-27-2022, 07:09 AM
