Dell 1908FPt monitor no backlight
  • SuperAman
    • Dec 2018
    • 119
    I have a Dell 1908FPt monitor with no backlight. When the monitor is turned on the first time or plugged in, the dell logo appears and there is no back light. If after I turn it off or on via the button there is no backlight. After I unplug it and let it sit for a little bit the dell logo appears and then backlight goes out immediately. I can see the images in the background by flashing a light on the screen.
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: Dell 1908FPt monitor no backlight
    Can be a problem on the power board (caps, lamps mosfets, lamps trasformers) or bad ccfls, or both. Did you recognize any color changes in the image when backlight was working, on the pink/reddish near top or bottom of the screen?
    Just open it and take photos of the power board. There's high voltage involved so if you're not familiar trash it.
    • DanPoka
      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
      by DanPoka
      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
      02-15-2025, 05:05 AM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • computerbacon79
      Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
      by computerbacon79
      The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
      05-06-2025, 06:43 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
