Dell 1908FPt monitor no backlight
  • SuperAman
    • Dec 2018
    • 119
    I have a Dell 1908FPt monitor with no backlight. When the monitor is turned on the first time or plugged in, the dell logo appears and there is no back light. If after I turn it off or on via the button there is no backlight. After I unplug it and let it sit for a little bit the dell logo appears and then backlight goes out immediately. I can see the images in the background by flashing a light on the screen.
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: Dell 1908FPt monitor no backlight
    Can be a problem on the power board (caps, lamps mosfets, lamps trasformers) or bad ccfls, or both. Did you recognize any color changes in the image when backlight was working, on the pink/reddish near top or bottom of the screen?
    Just open it and take photos of the power board. There's high voltage involved so if you're not familiar trash it.
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
