Westinghouse LCM-22w3
  • WillyPhister
    • Nov 2009
    • 6
    I received a broken 22" Westinghouse monitor that doesn't power on and I want to fix it. I'm pretty sure that the only thing wrong with it is the blown capxon capacitors and I want to replace them. Can somebody set me up with a shopping cart of all of the following capacitors from a good website, I would do it myself but I have very slow dial up and I don't know anything about caps and its confusing as hell trying to shop for them.
    capxon 2200uf10v p718 kf105c
    (2) capxon 1000uf25v p717 vent kf105c
    (3) capxon 220uf25v kf105c p716 vent
    capxon 330uf25v p716 vent kf105c
    capxon 1000uf10v vent p719 kf105c
    thanks
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Westinghouse LCM-22w3
    They are all Capxon KF series which are best replaced by Panasonic FM [or better].
    You didn't list your location.
    If you are in the US then Digikey is the place to go for Panny FM.
    Need to know the largest diameter and max length that will fit without clearance issues before I throw you a list.
    Mann-Made Global Warming.
    - Dr Seuss
    • WillyPhister
      • Nov 2009
      • 6
      Im in the US, and what are the available sizes that these caps come in?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I basically meant for you to tell me what to old ones are but sometimes the 'spot' will allow a bigger one.
        For example often the board is silk screened for a 10mm but they used an 8mm.
        Old cap is 8mm but a 10mm would fit so either an 8 or 10mm would work.
        Normal diameters are 4,5,6,6.3,8,10,12.5,13-up mm.
        Length can be anything but there might be a height limit as to what will fit in your gear. Happens a lot in screens when they use sheet metal panels to sheild EMI.
        I can't see it so you need to look-see if height matters.
        - Dr Seuss
        • WillyPhister
          • Nov 2009
          • 6
          Okay I'm back, I got sidetracked for a while.
          capxon 2200uf10v p718 kf105c (13 mm diameter, 21 mm tall)
          (Qty 2) capxon 1000uf25v p717 vent kf105c (10 mm diameter, 21 mm tall)
          (Qty 3) capxon 220uf25v kf105c p716 vent (12 mm tall 8 mm dia)
          capxon 330uf25v p716 vent kf105c (8 mm diameter, 16 mm tall)
          capxon 1000uf10v vent p719 kf105c (10 mm diameter, 16 mm tall)
          These are the caps that I need to replace, they dont have to be capxon, I would prefer better quality brand. Thanks
          • PlainBill
            • Feb 2009
            • 7034
            1 ea 2200uf10v 13 mm diameter, 21 mm tall) 565-1910-ND ELXZ100ELL222MK20S UCC @$.95
            2 ea 1000uf25v 10 mm diameter, 21 mm tall) 565-1962-ND ELXZ250ELL102MK20S UCC @$.95 * 12.5mm dia
            3 ea 220uf25v 12 mm tall 8 mm dia) 565-1954-ND ELXZ250ELL221MH12D UCC @$.44
            1 ea 330uf25v 8 mm diameter, 16 mm tall) 565-1795-ND ELXY250ELL331MJ16S UCC @$.63 * 10 mm dia
            1 ea 1000uf10v 10 mm diameter, 16 mm tall) 565-1905-ND ELXZ100ELL102MJ16S UCC @$.72
            PlainBill
            • WillyPhister
              • Nov 2009
              • 6
              thanks PlainBill, I got the caps ordered.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Some of those are kind'a pushing it on the Ripple and FM is cheaper.
                I usually just use Panny FM or Ruby MBZ to replace KF.
                Capxon KF 2200uf 10v 13mm - Ripple / ESR = 1750 / 0.041
                ELXZ100ELL222MK20S LXZ - Ripple / ESR = 1660 / 0.038
                LXZ 10v is a downgrade for Ripple.
                LXZ 16v is upgrade but cost more [$1.05/@]
                LXZ 2200uF 16v 12.5x25mm - Ripple / ESR = 1950 / 0.030
                http://search.digikey.com/scripts/Dk...me=565-1937-ND
                FM 16v is upgrade and same price [$0.95/@]
                FM 2200uF 16v 12.5x25mm - Ripple / ESR = 3190 / 0.015
                http://search.digikey.com/scripts/Dk...name=P12369-ND
                Capxon KF 1000uf 25v in 10mm - Does not exist in 10mm on data sheet
                Capxon KF 1000uf 25v 13mm diameter - Ripple / ESR = 1660 / 0.045
                Nearest KF 10x20mm - Ripple / ESR = 1320 / 0.062
                ELXZ250ELL102MK20S LXZ - Ripple / ESR = 1660 / 0.038
                LXZ is okay here.
                FM is upgrade and cheaper [$0.76/@] - Ripple / ESR = 555 / 0.120
                http://search.digikey.com/scripts/Dk...name=P12379-ND
                Capxon KF 220uf 25v 8 mm - Ripple / ESR = 550 / 0.150
                ELXZ250ELL221MH12D LXZ - Ripple / ESR = 555 / 0.120
                LXZ is good here.
                FM is upgrade and cheaper [$0.32/@] - Ripple / ESR = 950 / 0.056
                http://search.digikey.com/scripts/Dk...name=P12383-ND
                Capxon KF 330uf 25v 8mm - Does not exist in 8mm on data sheet
                Capxon KF 330uf 25v 10mm - Ripple / ESR = 820 / 0.114
                Nearest KF 8x12.5mm [no 8x16 there either] - Ripple / ESR = 550 / 0.150
                ELXY250ELL331MJ16S LXY - Ripple / ESR = 740 / 0.095
                - If the KF is 10mm then LXY is a downgrade for ripple.
                FM 8mm [35v] - Ripple / ESR = 1560 / 0.030 - $0.43/@
                http://search.digikey.com/scripts/Dk...name=P12414-ND
                FM 10mm [25v] - Ripple / ESR = 1290 / 0.038 - $0.37/@
                http://search.digikey.com/scripts/Dk...name=P12386-ND
                Capxon KF 1000uf 10v 10mm - Ripple / ESR = 1040 / 0.076
                ELXZ100ELL102MJ16S LXZ - Ripple / ESR = 1050 / 0.068
                LXZ is good here.
                FM [8x20mm] is upgrade and cheaper [$0.50/@] - Ripple / ESR = 1560 / 0.030
                http://search.digikey.com/scripts/Dk...name=P12354-ND
                - Dr Seuss
                • WillyPhister
                  • Nov 2009
                  • 6
                  Damn i already ordered, I will be alright right?
                  • WillyPhister
                    • Nov 2009
                    • 6
                    I got my order and replaced the capacitors and my monitor works now. Im so jacked, I cant believe it worked, thanks guys.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      CONGRATS!
                      - Fun isn't it!
                      You should fine as long as caps failed over quality issues vice being properly rated for the application.
                      Those you got that are rated less than the original aren't much less and if the unit was properly design spec'ed** there should be some 'wiggle room' in the needed ripple capacity in the circuit.
                      Worst case is it won't last as long as it might have using caps with higher ripple ratings.
                      ** Works like this:
                      The engineer works out the circuit and decides the ripple needs to be 'at least' 'this' much.
                      Then they find a cap that that handles 'at least' that much, which will usually be rated better than the minimum requirement.
                      - But: we can't know 'how much' more, so it's best to match [or improve on] the ratings of the original caps.
                      You caps probably didn't fail because their ratings[specs] are wrong for the circuit.
                      They probably failed because Capxon makes low quality parts.
                      - Dr Seuss
                      • Nicktronic
                        Westinghouse W55UW4620 No Video
                        by Nicktronic
                        Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                        So, backlights, no video, go! 🙂...
                        06-03-2024, 03:21 PM
                      • EBW
                        Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
                        by EBW
                        Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
                        10-27-2022, 06:32 PM
                      • Seville
                        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                        by Seville
                        Hello all!
                        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                        I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                        10-10-2022, 07:31 AM
                        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                        by momaka
                        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                        http://www.rmac.kingwin.com/products.../abt_650MM.asp
                        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                        What mostly drew me into buying it is its 2x PCI-E power connectors...
                        03-29-2022, 11:34 PM
                      • withalligators
                        Looking for best replacements for Capxons, but can't find data sheets
                        by withalligators
                        Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                        1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                        1 x Capxon 1000uf35v...
                        03-25-2022, 02:30 PM
