Dell E172fpb again
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Dell E172fpb again
    Well, the one I fixed and (mostly) recapped is acting up again.
    This time it will flash a picture of the windows desktop for a second, then go straight to black with the power light on solid.
    I read a couple of posts saying this is might be a bad backlight. I replaced all the caps on the power board except for 3 35v, 470uf elite's, they aren't bulged at all but who knows with elite.
    Could I try hooking up the screen from one of the others and see if it works then? Problem is I don't even know if those ones work either.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E172fpb again
    Substitution is always a valid way to troubleshoot these problems. Using another panel, using other CCFLs, using another power supply / inverter are all ways of determining where to look.
    Ideally, measuring the voltage and current to each CCFL would quickly pinpoint the problem area. Unfortunately, meters which will survive, let along give meaningful results with signals ranging from 650-1000 Volts at 100Khz are rather expensive. Measuring the return line may be possible - my $20 DMM from Harbor Freight is specified as measuring AC signals up to 400Hkz. Just make sure you don't hit the wrong pin on the connector.
    PlainBill
    • Mohonri
      • May 2009
      • 13
      Have you tested the inverter transistors? That's the most common failure mode I've seen. Check out this thread for more information.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • OntarioTL
        Dell 5410 greyed out BT
        by OntarioTL
        Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
        If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
        Dell Lattitude 5410
        Service Tag...
        07-25-2025, 01:28 PM
