*FIXED* Suyama MJ7CNA Monitor - backlight kept turning off after a second!
  • Bassquake
    • Aug 2009
    • 17
    My mum had a problem with this second hand monitor. Its not a bad one, and didnt want to chuck it if it was repairable.
    The backlight would turn off after a second. The image was still there as could be seen by shining a torch close to the screen.
    I ruled out the backlights as theres 2 in there and would be too much of a coincidence if both had gone at the same time. Could'nt find any bad caps either, but did notice a kind of scorch mark in the middle of one of the toroids. So I looked underneath, and it looked like a dry solder. Resoldered it, and it now works fine!!! Yay!
    Hope this helps others who may have similar symptoms.
  • Xtral
    • Dec 2013
    Re: *FIXED* Suyama MJ7CNA Monitor - backlight kept turning off after a second!
    I cannot get the cabinet open Is it just to prise it appart after taking out 6 screws I do not have a manual Thank you Graham
    • Rtech
      • Jul 2010
      • 1095
      See if you can lift the front bezel a little,and gently pull ,I usually start at the top in the centre,and then if it gives you enough room to get a flat knife etc in the gap made, work your way around.
        by momaka
        03-15-2023, 10:17 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
        Wise Wing F199 19'' LCD monitor - recapped
        by momaka
        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
        When I saw the Craigslist post, I wasn't...
        08-24-2020, 10:58 AM
