Acer S277HK horizontal flickering lines
  • Kuhanzzi
    • 20
    • Suomi
    I have Acer S277HK 4k 27" display, and the problem is it has flickering horizontal lines. Display panel is M270QAN01.1
    I disassembled monitor and checked every connection and looked for obivious marks of failure. It seems like earlier owner have replaced power unit caps at some point, I will replace those when I get new caps, but they seemed okay.
    Horizontal lines are more clearly visible at top of display.
    Here is photo of mainboard from internet, I can take better photo myself tomorrow
    Does anyone have any ideas what to check first and where to start? What could cause this?
    Here is video for reference
    https://youtu.be/mn9KQsbClbQ
    https://youtu.be/eBiamjcMqBU
  • GrantR
    • Jun 2020
    Re: Acer S277HK horizontal flickering lines
    I have the same issue with the same screen. Were you able to fix the problem? Did you fix the caps? I am hesitant to order a new main board if that isn't the issue.
    • 98karlh
      • Jul 2020
      • Denmark
      Hoping to keep this tread alive exact same issue.
      Got this screen from an exchange student going home, and hoping to fix and use it.
      Hope to hear from anyone who has found the cause of the issue
      • Kuhanzzi
        • 20
        • Suomi
        No, problem is still there. Any help will be appreciated.
        • 98karlh
          • Jul 2020
          • Denmark
          I dont know if this is a solve per se.
          I hooked up another power adapter I had lying around and left it there.
          I kept using the monitor even though it looked like shit.
          After 1-3 weeks (honestly dont remember), it went to full brightness and stopped the shimmering.
          I have no idea how this voodoo bs works, but I am just leaving my monitor alone for now and being happy taht it works.
          Did the clean power from my blessed adapter just flush out the toxin buildup from the previous bad connector, and now the monitor is healed? best explanation so far.
          • JuhaniV
            • Nov 2020
            • Finland
            I have the same problem, but I have a hard time getting this thing apart. So could someone please point me in the right direction to get inside this damm thing?
            • reessi
              ACER BM320 Monitor - Horizonal Flickering Lines After a While
              by reessi
              The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
              They are black on the right and gradually fade to nothing on the far left.
              They start either after 5 mins or up to 2 hours after so annoying for testing.
              They flicker continuously very fast! With a slight pause milli-second every second.
              Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
              I tested each half by removing the first the left flex from...
              06-03-2025, 09:58 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • mrsith
              Samsung UE70TU7100 - flickering horizontal lines
              by mrsith
              Hello again good souls.
              Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
              I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
              02-13-2023, 05:36 AM
            • Guybrush
              Dell U3419W horizontal lines and flickering
              by Guybrush
              After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
              Seller claims; "but due to sun damage has some grey lines going through it"
              https://i.imgur.com/VpTcZFn.mp4
              Chris...
              10-23-2023, 06:17 PM
              09-06-2024, 05:27 AM
