dell 17" 1707FPVt LCD Monitor
  • smartkid808
    • Oct 2009
    Anyone successfully repaired a dell 17" 1707FPVt lcd monitor. The 2 bad caps i see are CapXon kf105c 1000uf/10v. I bought these.. I hope I got the right ones
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
    I got 2 different ones because I didn't know what how big (fat/tall) the cap was. Do you think these will work. I jus no like blow up my office.
    thanks for the help
  • etnietering
    • Apr 2009
    • 379
    Re: dell 17" 1707FPVt LCD Monitor
    Yeah either of those will work. The CapXon has a rated ripple current capacity of 1040mA, according to the datasheet. According to the NCC datasheet for the ones you ordered, the 8mm ones have 1050mA ripple current capacity, and the 10mm ones can handle 1210mA. So, that being said, if the 10mm ones will fit, it would be preferable to use them, but the 8mm ones would be fine too. The general consensus around here I believe is that CapXons are overrated to begin with, so either will work just fine. If you see any other CapXon that you can replace, do it, chances are they aren't far off. I fixed a Dell LCD monitor and there were 3 CapXon vented through the top, and 4 or 5 vented through the bottom.
    Good luck!
    • Player2
      • Aug 2009
      • 98
      Do they match the uF and voltage ratings of the old caps? You should also replace any other CrapXon caps that are in there, even if they don't show signs of failure now they will soon.
      EDIT: Looks like I was a little late
      • smartkid808
        • Oct 2009
        Should I try replace these, then make sure it works first. then order the others? there are more of the same brand on the board but was not pop or anything. I no like spend too much money and it not work. This is for my company thats why. I had a user call me saying it doesnt work so I swapper her out. When I went to her desk, the green light was blinking, but i could not get no display (not even the menu button worked). Now it doesnt even power on.
        thanks again
        • etnietering
          • Apr 2009
          • 379
          Well replace the blown ones first, and any other 1000uF/10v ones you see that you can replace, and then make sure it works. Then if I were you I'd go ahead and replace all the other CapXon, otherwise you'll just be seeing it again to replace them in not too long
          • smartkid808
            • Oct 2009
            Thanks I will do that.
            • s10outhpaw
              • Jul 2011
              • 6
              this worked for one monitor, got it back to working, thanks for the advice. I did the same on a second one and it act like it is working just no picture. the display screen is good I powered it up with the other monitor's system board.
              • Borse2008
                by Borse2008
                • There’s
                Today, 04:55 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Jesus Coder
                Issues Reviving Old Dell 2408WFPb Monitor
                by Jesus Coder
                I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                06-25-2023, 02:33 PM
              • ChristianBr01
                Dell 34 inch U3419W Monitor with thin stripes on partial screen
                by ChristianBr01
                I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                Does someone have seen this before?...
                05-23-2025, 06:06 AM
