SCEPTRE X7S-Naga dets wavy after 10 min.
  • Maugli
    • Jun 2008
    • 5
    Hi Guys .. this is my first post. This morning started having issues with picture clarity. The whole screen gets wavy no straight lines. I have opened the case and looked at the power supply. No bulged caps observed. the board is
    LL033 Rev.1 if it was a CRT i woudl say a filter cap is about to fail.. but with LCD i coudl use some help.
    Thank you for your help.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: SCEPTRE X7S-Naga dets wavy after 10 min.
    Noise from PSU (Oscillating voltage). If it is internal PSU, post brand & series of caps installed (& pics if available) and one of our seniors would suggest replacements in no time if the case is bad caps.
    And Welcome
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • Maugli
      • Jun 2008
      • 5
      It has external power Supply.. Y have replaced it with another one from Viewsonic LCD monitor. The result is the same.. This is the only picture i found of the board.. funny .. it is on eBay in Germany. :-)
      The caps are Elite (85c) and Jamicon (105c)
      http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
      • spirittoo
        Sceptre 48" TV backlight LED`s
        by spirittoo
        Trying to fix a backlight problem with a Sceptre 48" TV.
        I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
        So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
        Anyone know how I can remove those leds without damaging them?
        11-11-2023, 10:23 AM
      • tom_h
        Sceptre X505BV, blue LED, no display
        by tom_h
        Hello all,
        I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
        and longer to come on, now it will no longer display any image. Original symptoms
        are the red standby LED would turn to blue immediately when pressing the power on
        button, but there would be a delay for the "SCEPTRE" image to appear on the screen
        and backlight to come on. The delay kept getting longer, then it would go from blue
        LED back to red. Then when I pressed the power on button again it would bring the
        display up and work fine....
        10-05-2023, 06:53 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • DoorOfTime
        Sceptre X405BV -- Backlight on in standby?
        by DoorOfTime
        I have a sceptre x405bv TV with bad LED strips. The screen displays dimly over the good LED's, and on disassembling it looks like over half of them are dead tested by multimeter diode test on test points. Plugging it in with the panel disconnected (this TV has a combined power and main board), the backlights immediately receive power when the set is plugged in. When the power button is pressed, it flashes brightly then dims, but additional LED's turn or flicker. When it's turned off again some back lights stay on.
        Before I order replacement strips I wanted to ask if it is typical...
        04-04-2022, 10:13 AM
      • BruceLeeRoy
        Sceptre x322bv No Backlight
        by BruceLeeRoy
        I have a Sceptre x322bv with no backlight, trying to find the pinout on the LED supply cn5 red wires have 12v and blue wires have 1.23v Does anyone know what voltages I should be getting on this connector?...
        10-24-2021, 02:00 PM
