Dell U3011 - Troubleshooting the Power Supply board PS-2201-3-HF
  • QUAKE
    • Nov 2021
    Re: Dell U3011 - Troubleshooting the Power Supply board PS-2201-3-HF
    Registered to say thank you.
    • peu99
      • May 2021
      • Brasil
      The solution is here
      https://www.youtube.com/watch?v=3QcHkUugEHs
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • Nicktronic
        Samsung Power Supply Board BN44-00874F
        by Nicktronic
        Hey everyone,
        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
        Anybody...
        03-17-2025, 06:20 AM
      • Per Eriksson
        Samsung BN44-00808D power supply board troubleshooting
        by Per Eriksson
        I was given a samsung 65" lcd tv which is "dead" after a lightning strike.
        Power supply board is a BN44-00808D , also have the marking L65S6N_FSM
        Main board is a BN94-10803V
        I've made some simple test.
        With main board connected nothing happens when plugged in, no blinking lights or sounds.
        Also kept it plugged in for a while and checked on the boards with a thermal camera, no hot spots detected.
        With the main board disconnected the backlights turn on and stay on.
        Checked the voltages...
        06-01-2021, 02:51 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
