Dell 2412m picture problem
  • todd321
    • Oct 2016
    • Hungary
    Hello!
    I need some help with my Dell 2412m 24" monitor with the display failing shown on the video below.
    https://youtu.be/9Uaw_PDpr4o
    I'm not really familiar with flat panel displays, so feel free to correct me.
    This monitor has an LG LM240WU8-SLA1-611 t-con(?) board, and a 4H.1GH01.A00 scaler board(?).
    I have created a list of voltages measured on the t-con(?) panels test points. No idea what SOE, POL, FLK1 and FLK2 are.
    Pin Voltage
    VLCD 16,142V
    VCC 3,295V
    VGL -4,2V fluctuating approx. 400mV
    VGH 25,2V
    VCOM_L 6,406V
    VCOM_R 6,406V
    POL 1,639V
    SOE 0,395V
    FLK1 2,402V
    FLK2 3,278V
    VST -3,6V fluctuating approx. 400mV
    VDD_O from 25V to -4V jumping
    VDD_E from 25V to -4V
    V1 15,144V
    V2 14,505V
    V3 12,446V
    V4 11,369V
    V5 10,253V
    V6 8,475V
    V7 7,954V
    V8 7,516V
    V9 7,005V
    V10 5,219V
    V11 4,074V
    V12 3,022V
    V13 0,946V
    V14 0,318V
    Can anyone point me into some directions where to look? What I found a bit strange is the VGL voltage, I checked it with a scope.
    https://photos.app.goo.gl/cwv5aGG1Q3KVWH7b7
  • todd321
    • Oct 2016
    • Hungary
    Re: Dell 2412m picture problem
    Found out that SOE is source enabled, POL is for polarity, FLKX is flicker control.
    • captainKKK
      • Sep 2018
      • 287
      What voltages are listed on the COF IC datasheet? Likely VGL should be around -6 and VGH around + 25. Have you checked all the fuses? My guess is going to be US1, but it's only my guess.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Cemal Odabasioglu
        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
        by Cemal Odabasioglu
        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
        Observations...
        01-14-2025, 03:54 PM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • timeless
        Dell U2518 no picture
        by timeless
        I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
        There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
        04-14-2024, 08:30 AM
