Re: Apple 27" Cinema Display (A1316) has trouble turning backlight on
So, I ended up trying a replacement power supply as I got one for a lower price than they usually go. Issue persists in the exact same way.
So, next suspect I guess is the main board, which also contains the backlight circuitry. I’ve attached a stock photo of this board to the post. The backlight connector is the black plastic connector on the bottom left/middle area.
Seems like there are a lot of SMD electrolytic capacitors, as well as some voltage regulators (?) in that region. I can replace the whole board for $35, but are there any things I can diagnose now with a multimeter?
Also, is it possible that failing LEDs would require more current to start up, thus causing an intermittent failure to turn on the backlight?
I guess I’ll try the hairdryer trick on the main board as well.
I agree with RJ. In order to test this, heat up the caps with a hair dryer, so the caps are warm, but not hot that you burn yourself. Then turn the monitor on and see what happens.Leave a comment:
This does seem like a bad capacitor on the power supply, The weak capacitor will take some time to charge to the full voltage, so by turning down the brightness/backlight will allow the cap to charge with minimum current being drawn from the circuit. Once the cap is charged, you can then draw more current from that circuit.
If the brightness is tured up at start, the caps voltage will be too low tripping the led's error circuit and shutting it down.Leave a comment:
If I turn the display brightness all the way down before connecting the monitor (and thereby turning it on, as it has no physical button of any kind), the backlight successfully turns on, after which I can turn it up as much as I want with no issues.
Basically, once the backlight is on, things are fine. No problems.
But getting the backlight on requires the brightness to be turned way down, or it won't turn on.Leave a comment:
If your back lights stay on, when the level is turned down to next to nothing, then one or more LED's in the back light strip could be still bad. LED's can fail like that.Leave a comment:
I have an Apple A1316 27” Display (non-Thunderbolt) that is exhibiting a weird backlight issue.
When first plugged into a computer, when it receives a signal, the backlight flickers briefly but fails to stay on. Otherwise the monitor works fine (the computer thinks another monitor is attached, I can see that it is displaying using a flashlight).
I tried turning it's brightness all the way down before connecting it. When connected, it flickered, then stayed on. So it seems that it can barely muster enough energy to turn the backlight on, but once it's on, it's fine. Other people have had issues with no backlight after a period of functionality, my issue seems to be kind of the opposite.
What should I start testing on this? It seems like the power supply just can't handle the load it's getting all of the sudden.Tags: None
by roxboy1984Please could someone help or advise. I have an Apple Cinema Display A1316 and it all of a sudden is taking a really long time to come on. I assume it's probably a capacitor related issue on the power board, I'm just wondering if anyone has experienced something similar and if these monitors are easy and or worth trying to get repaired. Thanks in advance for the help.
by a_p3rsonHi there,
I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
This daughterboard uses an interesting...-
Channel: Schematic Requests ONLY!
04-21-2025, 11:41 PM -
by mikiottyHi everyone!
A friend of mine gave me an Apple Cinema Display 23" A1082, the aluminum one from late 2005.
The display turns on, as I can see the backlight increase or decrease following the input from the controls.
The computer sees the monitor, and supposedly sends signal to it, but all I can see is a black screen.
Ideas?
Thanks-
04-16-2020, 04:09 AM -
This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-12-2024, 02:30 PM
This specification for the HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Apple AirPods Pro boardview and 1030 G4 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 07:50 PM
- Loading...
