AOC LCD recap
  • pentium
    • Mar 2006
    • 2778
    AOC LCD recap
    I got an AOC LM729 which after a few seconds or so kicks out the backlight but still displays a picture so I opened it up and while I did not see any bulging caps I still pulled two Elite 1000uf, 16v and two hermei 470uf, 16v caps and will be repalcing them tomorrow. Yes there were two more hermei caps on the inverter board but they were both rated 150uf, 25v and four TL caps on a board between the inverter and video board rated 16v 470uf and again, not one of these caps were bulging. Should I replace them all anyways? I'm heading into town later and if I don't buy the caps this trip I won't be able to get into town for another week.
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: AOC LCD recap
    managed to revive two other LCD panels but of course, the AOC panel still switches the backlight off after a few seconds. >:/
    Find Nedry!
    • EGuevarae
      • Nov 2008
      • 1336
      Re: AOC LCD recap
      Replace them, you are there anyway. Or at least buy the replacements just in case. You can't have too much caps anyway...
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • pentium
        • Mar 2006
        • 2778
        Re: AOC LCD recap
        You are gonna have to wait until next week as I went into town today.
        Find Nedry!
        • pentium
          • Mar 2006
          • 2778
          Re: AOC LCD recap
          BuMP.
          Recapped the board and it fixed nothing.
          then yesterday I find another wrecked AOC monitor I salvage the boards from and still, the backlight goes on for a bit and then switches off.
          Find Nedry!
          • Bobdee
            • Jun 2008
            • 461
            Re: AOC LCD recap
            BuMP.
            Sounds like Inverter or CCFLs, check out the inverter transistors and the solder joints on on inverter transformers
            Pictures would help
            Bob
            • Toasty
              • Jul 2007
              • 4171
              Re: AOC LCD recap
              Agree. Bad tubes -or- shorted transformer winding would draw excess current & will trip the inverter protection circuit.
              veritas odium parit
              • Bobdee
                • Jun 2008
                • 461
                Re: AOC LCD recap
                BuMP.
                Also found this (new to me)
                A utube video on a fix for a Blue Ceramic cap on inverter with on/off problem
                http://www.youtube.com/watch?v=jQeEy...eature=related
                bob
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: AOC LCD recap
                  bob
                  Not a ceramic. He mentions a 16 volt, 1000uF capacitor.
                  I'm not sure how much faith I would place in this video. He was replacing one of the film caps in the inverter. This appears to be the same inverter circuit used in the Dell E172FPb / E173FPb monitors. There are a couple of electrolytics in the inverter, and the value he referenced is definitely an electrolytic cap, but the one he appeared to be changing was a film cap. Now if that cap was bad, it would screw up that half of the inverter.
                  PlainBill
                  • Bobdee
                    • Jun 2008
                    • 461
                    Re: AOC LCD recap
                    PlainBill
                    I do agree
                    It was the Blue Film cap in between the transistors, my mistake calling it a ceramic
                    I have seen the Grey box type fail there with visual signs but never the Blue type, I do not recall ever reading about this Blue cap failing in the Monitor forum before so I think its one to keep in mind
                    Bob
                    • wkydvdfan
                      • Oct 2009
                      Re: AOC LCD recap
                      I have the same problem and have recapped the board with no success. Anybody have a suggestion? I'm new and I too saw him replace the film cap. Is this standard film cap or is their a part number like the capacitors?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: AOC LCD recap
                        Which 'Same problem'? Two seconds to black? No backlights? You mentioned you recapped the board. What brand and series of capacitor did you use?
                        Please post pictures (top and bottom) of the power supply / inverter board. I hate pretending I have a crystal ball.
                        The joker on the Youtube video was pulling a switch. The cap he described was an electrolytic; the one he replaced was a film cap. (Not too cool).
                        For the record, within the past year the following causes for the 'two seconds to black' problem have been identified:
                        Bad transformer.
                        Glue around HV caps
                        Bad CCFL
                        Bad wiring on CCFL
                        Bent pin on connector.
                        Wrong replacement caps.
                        Bad transistor
                        Bad capacitor
                        PlainBill
                        • wkydvdfan
                          • Oct 2009
                          Re: AOC LCD recap
                          I'm working 12 hour days and I'll get pics as soon as possible!
                          Yes 2 seconds of display then no back light.
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                            by momaka
                            03-15-2023, 10:17 PM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • fl0w
                            GeForce 6800GT recap, need help identifying caps and finding replacements
                            by fl0w
                            I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
                            But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
                            I need to replace:
                            • 2x 2.5V 1500µF => I plan to use this
                            • 2x 16V 330µF=> I plan to use this
                            • 1x 6.3V 680µF=> I plan to use this
                            Am I correct with the cap choices?
                            Thanks for...
                            10-02-2024, 11:28 AM
