Syncmaster 245bw going dim/bright at times after all caps/resistors replaced.
  • OberAgain
    • Nov 2014
    • 25
    I just did a replacement of all caps/resistors for the 245bw, I have done it a few times prior to fix my other monitors and this was definitely the second+ repair done on this board (first by me, bought off ebay)
    Anyways, now when windows dialog boxes come up it gets dim, or with I use this Windows Tweaker program it gets really bright then slowly dims back down and to a yellowish tint after every change made. The monitor works fairly decent as long as you ignore the random changes in brightness when you open/close anything.
    The previous repair was done really sloppy and made it extremely tough to get the parts out without doing damage, on the 3x 68ohm resistors I had a few spots where I thought I lost the trace pad but I was able to solder to it - just not as clean as I would hope and do not expect it to be easily fixed again unless I replace with a single 200ohm resistor, even then I have to work with the worst damaged pad/hole.
    Also both me and a friend notice this purple outline of stuff that is not on screen just barely visible on completely black backgrounds - sometimes it acts up and gets more visible, turned down brightness to reduce effect.
    One random stupid question, I have failed to replace that plastic "shield" on all the monitors that I have repaired (just forgot about it when putting back together) but its just a piece of thin semi-transparent plastic do I am not sure if it really shields anything but a friend tried to tell me he thought that the purple looked like possible interference? I thought it was simply a cover to make sure no one touches the more dangerous section of the PCB?
    Is it likely that this is a power board issue or one of the other parts?
    I have searched for other people reporting similar things with the model but couldn't find any.
    Thank you all as usual, your all great! Best helpful site on the web!
  • CapLeaker
    Leaking Member
    • 8146
    Re: Syncmaster 245bw going dim/bright at times after all caps/resistors replaced.
    can you upload some high resolution, straight shot pictures of your boards?
    • OberAgain
      • Nov 2014
      • 25
      Well, I was hoping it was something that would be somewhat identifiable by the symptoms, the next time I take it apart I will take the pictures. Thank you for your time and I apologize for not having the pictures ready to start with.
      • CapLeaker
        Leaking Member
        • 8146
        are these three 68Ohm resistors in series or in parallel?
        • OberAgain
          • Nov 2014
          • 25
          Series, they are a common problem in Syncmaster 245bw's
          • CapLeaker
            Leaking Member
            • 8146
            what is the dim voltage doing?
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • brightest_z
              Hot Air Blew Away Resistors Near Bios
              by brightest_z
              Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
              Does anyone with more knowledge, and experience than I, know if this is the case?
              12-11-2024, 08:34 PM
            • jinu_j
              LED driver circuit. Burnt Resistors
              by jinu_j
              Hi Folks
              This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
              Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
              But i have some queries on this circuit
              1. The resistors that burnt to crisp...
              08-26-2020, 01:24 AM
            • Schwoin
              Philips 243v5lhsb00 Monitor Picture too bright
              by Schwoin
              Hey everyone,
              the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
              While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
              you can see them on the top half of the photo.
              At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
              03-21-2023, 12:40 PM
            • repair-it
              Pioneer VSX-40 ,Trying to ID these resistors
              by repair-it
              I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
              12-16-2024, 02:08 PM
