Viewsonic VA800 with rolling lines
  • fzabkar
    • Mar 2009
    • 772
    Re: Viewsonic VA800 with rolling lines
    You could connect the +12V outputs of two old AT power supplies in series, with the 240V/120V output of one connected to the mains input the other. That way one AC on/off switch can operate both PSUs. Make sure that the secondary grounds of each supply are isolated from the case.
    A more sophisticated way would be to modify one PSU by removing the +5V, +3.3V, -12V and -5V rectifiers. Disconnect the grounded centre tap of the +12V transformer secondary winding. Then add an additional common anode dual Schottky diode pair (in the spot vacated by the +5V dual rectifier) to create a 24V Schottky bridge rectifier. Modify the values of the feedback resistors for the error amp in the PWM regulator so that it senses +24V rather than +5V/+12V.
    Make appropriate changes or deletions to the PowerGood circuitry, if required. Also replace the capacitor(s) on the original +12V rail (now +24V) with 35V or 50V types.
    • EGuevarae
      • Nov 2008
      • 1336
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • Magyk
        • Nov 2010
        did replacing the electrolytics work?
        None of the caps were bulging on mine...
        Here it is.
        http://www.youtube.com/watch?v=bkTfs5BzGfA
        • MBLeo
          • Dec 2010
          • 16
          Originally posted by hulla
          I just found a way to connect a spare computer p/s to the monitor and got the same rolling lines problem.
          Are you running a fan anywhere near the monitor?
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
