Dell E773C problem.
  • wan901
    • Jun 2007
    • 69
    Dell E773C problem.
    Hi there guys, I need ur help. My dell CRT E773C monitor have a problem like No Display. But have power on it. i think the vga connector problem. does anyone have the kind of problem like this ? can help me out ? if someone have the service manual that might can help me out.. ^_^
  • bullwinkle
    • May 2009
    • 107
    Re: Dell E773C problem.
    You have to isolate the problem. Start with the PSU area or the Trigger Circuit on the ON/OFF area. Dont forget to check for bloated caps.
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • toti24
      (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
      by toti24
      dell precision m4600 laptop
      i7 2760qm
      8gb ram 750gb HDD
      intel hd 3000 integraded and nvidia quadro 2000m
      pleasea bear with me english isnt my language and ill try to be as clear as possible
      note i live in mexico in a very small town..
      thank you.
      laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
      the brick happened when i was installing win 10 using usb.
      used rufus and officia microsoft.iso
      it finished copying files from usb...
      03-06-2022, 08:39 PM
    • SDNarcia
      Dell 15R-5521 keyboard problem (KBC?)
      by SDNarcia
      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
      As additional information,...
      07-20-2024, 10:47 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Achille15
      Dell N5110 problem
      by Achille15
      so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
      03-29-2025, 04:41 PM
