Dell UltraSharp 2408WFP Monitor Help!
  • ABuNeNe
    • Jul 2014
    • 25
    • India
    Hi I'm using this monitor for a number of years and recently it suddenly goes into blank screen.
    Found a inverter, Slm-240d7 Rev 0.2, and tried to do a replacement but having a hard time connecting the white connectors (top) to the bottom (are these CCFL?) as seen in the picture below. Any idea?
    Re: Dell UltraSharp 2408WFP Monitor Help!
    The black plack plastic piece which those lamp sockets are attached to should never be removed form the chassis some of the lamp may have been damaged now, now you need to disassemble the LCD panel, put the black lamp socket assembly back in place and then clip the CCFL back to each lamp socket carefully. The inverter board has fingers that fit ito the black lamp socket assembly: https://www.ebay.com/itm/Dell-2408WF.../122760356177?
    BTW, 7 CCFL's ends are blackened which means the lamps are worn out.
    • ABuNeNe
      • Jul 2014
      • 25
      • India
      Thanks for your reply, budm.
      Will give up reviving this monitor then.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • nheather
        Have I Inadvertently Fixed My Dell Ultrasharp U2312 Monitor
        by nheather
        For the last few weeks I have been trying on and off to fix my Dell Ultrasharp U2312.
        I'd read that the 1084-33 voltage regulator on the logic board often needs replacing but they are pretty difficult to find in the UK, plus I don't have the hot air tools needed to replace it properly so I decided to check it instead.
        It was getting a 5.16V input and a 3.41V output so that seemed fine so I started looking at the capacitors that I could easily and cheaply replace.
        The symptoms were that the monitor would be perfect for a few minutes and then the flickering...
        03-19-2022, 05:59 AM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
