Dell E2310Hc LED Conversion Project
  • Ndabu
    • Jul 2022
    • 6
    • Albania
    Re: Dell E2310Hc LED Conversion Project
    Greetings, I was trying a similar mod on an LCD monitor as well , model :
    AOC TFT22W90PS.
    I wanted to know if u completely followed the directions in the previous responses done by budm. and if u did have plausible brightness with no dim signal on the led driver.
    I know this discussion is a bit old, never the less I appreciate the discussion and the clarity provided by all of u guys.
    Thank you in advance!
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • Garret Matt.
      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
      by Garret Matt.
      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
      Thank you in advance for any assistance you can render.
      Inductor In question. Buzzes like...
      06-20-2025, 01:21 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
