Samsung Syncmaster 2333
  • Sa85
    • Jul 2018
    • 3
    • South Africa
    Hi guys
    I have a Samsung syncmaster 2333, that works fine, but has trouble displaying certain colours.
    Light blue seems to trigger it. The screen freezes and then slowly starts to turn white (it seems to happen less when the screen has warmed up).
    If I change the image on the screen, it works perfectly again.
    I have opened it up and cannot see any bad caps on the PSU board.
    Backlights are working fine.
    When I put a finger on the ribbon between the mainboard and T-con, it fixes the problem.
    Its not a connection problem, because it doesn't have an effect if I use anything besides my finger.
    Any help would be appreciated.
  • R_J
    • 9594
    Re: Samsung Syncmaster 2333
    There are 2 regulator ic's on the logic board, It is possible that the caps around them are going bad. Post a couple good quality pictures of the boards.
    Does your board look like this? these caps could be bad
    • Sa85
      • Jul 2018
      • 3
      • South Africa
      Yes, looks like the same board.
      Should I just replace those caps?
      • R_J
        • 9594
        I don't know if it will fix your problem but when those caps get weak the regulator ic's can do strange things and cause problems, so give it a try.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
          by JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
          Please help. Thanks in advance!
          08-12-2025, 11:45 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
