Benq Power Supply DS-1107A
  • Jimisnotabot
    • Apr 2009
    Howdy all, I recently had my Benq FP767-12 stop working on me. After some investigating, i'm sure it's the power supply. I've checked the caps visually and the fuse inside the monitor and all seem fine. I decided i'd first try to re-solder the components before I'd start replacing caps and FET's.
    This is where I slipped up. During the course of the resoldering I think I may have soldered a few components together that should not have been. I blame my shoddy vision.
    Anyhow, would anyone out there have an electrical schematic for the power supply board DS-1107A or a high resolution picture of the back of the PCB so I can check the components to make sure I havent stuffed up?
    Any help would be appreciated.
  • mekktom
    • Jul 2009
    Re: Benq Power Supply DS-1107A
    I had a problem with the same monitor. After hours of search I found a russian website where you can download schematics for this panel. (and for much more models...) Fortunately the documents are in english.
    link
    You did not tell about the failure of the monitor, but if it is the backlight inverter, usually the Q739, Q740, Q759, Q760 transistors (type 5707) are dead. Check PF751 fuse as well.
    Hope this helps.
    • EGuevarae
      • Nov 2008
      • 1336
      Hope this helps.
      I agree with mekktom on that one. That are the common failure among that model. You should replace them and resolder the transformer contacts.
      And welcome both to Badcaps.Net
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • nico
        • Sep 2009
        • 14
        I have the same problem with benq board, ds1107a, 48.L1A02.A31, but I don't find the transistor Q739,740,759 and 760.
        I don't find the fuse too.
        thank for help me !!
        • Bobdee
          • Jun 2008
          • 461
          hello
          Go to this link
          https://www.badcaps.net/forum/attach...chmentid=11049
          The fuse is on the right hand bottom corner of the white rectangle heatsink left side of the board three quarters up
          The transistors are
          Two in the middle of the 4 transformers on the bottom of picture one on top of the grey box capacitor another at bottom
          the other 2 are to the left of the 4 transformers
          Dont forget to resolder the 4 transformers after you done repairs or the new parts will go again probably
          • nico
            • Sep 2009
            • 14
            I have replaced all the transistors, but I have 2 that become very hot, the 2 are at the left of the transformers, the self(solenoid?) above the transistors was very hot too.
            No output at all !!
            • Bobdee
              • Jun 2008
              • 461
              No output at all !!
              That capacitor (solenoid) C801 will need replacing
              and best to replace C802 as well on the inverter, If your P/Supply was at fault then chances are both sides of inverter would be hot
              So your problem sounds like its the Inverter or CCFLs
              Did you resolder the 4 transformers???
              You have not told us anything about the problem
              Are the backlights working fully, briefly, or not at all???
              bob
              When you replaced transistors,did you replace with same type???
              • nico
                • Sep 2009
                • 14
                My monitor run for a few second before coming black, so backlight working briefly. but since I changed the 4 transistors, it didn't run and became very hot like I describe in my last post.
                I resolded the 4 transformers. I didn't use the same transistors because i can't find, I used mosfet, this one:
                https://cdn.badcaps-static.com/pdfs/...c0868d5c4f.pdf
                I think they are good.
                I try to change the capacitor and I give you result after.
                thanks for help !!!
                • Bobdee
                  • Jun 2008
                  • 461
                  thanks for help !!!
                  If the old transistors were C5707s or 6s then they are readily available on EBAY just search 2SC5707 or 2SC5706
                  It may be that the fault is in the side thats not heating up and the other pair are getting hot because they are not the correct ones, as I have read in other threads that diffrent transistors get very hot but you have said you put mosfets in this, that could be risky as the are a diffrent component
                  • nico
                    • Sep 2009
                    • 14
                    OK, the old transistor were C5707s, i found them in farnell, i'll command them, normaly I 'll receive them on thursday ...
                    I'll give you some new
                    many thanks
                    • nico
                      • Sep 2009
                      • 14
                      hello,
                      I received my components today, very fast farnell !!!
                      so I have change the 4 transistors and it's ok now !!!
                      many thank for your help !!!
                      • mecklan
                        • Oct 2008
                        • 5
                        i have an FP767-12 / Q7C3. 4x 2SC5707, 2x MosFets and fuse were replaced. Thereafter, the monitor can only be manually switched on/off with the power button, so no more about the connection cable or the PC. What could still be broken?
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Short in the BL_ON line/signal. May be a recently soldered components. Double check your soldering on the MOSFETS and Transistors.
                          • GeForce GT1050
                          • Phlashman
                            • Jul 2010
                            This board is completely different from the DS-1107A I'm testing??? Although the numbers do correspond with the parts.
