Gateway fpd1975w
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Gateway fpd1975w
    Hi PlainBill. Huge fan. All the caps on the inverter were Su'scon caps. After reading an article on ESR, I must invest in an ESR meter. WoW, they are not cheap on ebay. I would like to know if recapping this board has fixed anyone else's FPD1975w monitor before this investment.
    • PlainBill
      • Feb 2009
      • 7034
      Su'scon caps are on the list of bad caps.
      eBay is an excellent source for many things. ESR meters aren't one of them. Two possible candidates are the Bob Parker Blue ESR meter from Anatek, and this little wonder. (Look at post number 63 in the thread).
      PlainBill
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Since recapping the board is tons cheaper than buying the ESR meter, for now, I'll go that route and see where it lands me. I should be able to do this today after I go to the local electronics parts store to get some off values that this board requires.
        • PlainBill
          • Feb 2009
          • 7034
          Do make sure that you get caps rated for low ESR applications.
          PlainBill
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Ok recapped board and still the same symptoms. I might look up a replacement for the processor board. Something is keeping this in a test loop. I searched the manual to try to see if there was a way to put it in this mode from normal mode - nothing found yet. Any suggestions?
            • PlainBill
              • Feb 2009
              • 7034
              We're getting out into the gray area, but do a search on 'reset monitor'. I've heard of some strange things happening if the eeprom on the monitor gets corrupted, but this is beyond that. Still, if you can find the reset sequence, that might (emphasis on might) fix it.
              PlainBill
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                #27
                Well, I did more research and found a blog where it speaks of this same failure.
                http://gatewaymonitors.blogspot.com/...?commentPage=2
                The one message listed from "September 4, 2009 1:58 PM" is the same.
                I think this thing is very close to working, i dont wanna give up on it just yet.
                • Dist
                  • Apr 2010
                  • 4
                  #28
                  Hello All... First post here. I also have a Gateway FPD1975W that a friend of mine just gave to me because it seems to have some problems as well. With it plugged in, it will automatically try and turn on but won't stay on. It will flash the Gateway logo and go back to black over and over and over.. so I know the actual LCD screen itself works.. I have it all taken apart and I took pictures of both circuit boards inside.. I'm attaching pictures of both. I am just wondering if I need to try the capacitor replacement solution.. or what I need to do based on the pictures I've provided.
                  EDIT:
                  I tried to upload them as attachments and they were too large so I'm going to add links to them from my webpage..
                  Inverter Board Back
                  Inverter Board Front
                  Inverter Board Front1
                  Inverter Board Front2
                  Inverter Board Front3
                  Video Board Back
                  Video Board Front
                  • PlainBill
                    • Feb 2009
                    • 7034
                    EDIT:
                    Inverter Board Back
                    Video Board Back
                    Video Board Front
                    Start by reading this FAQ. Then use some editing software to reduce the size of the pictures. I've already had one picture Paint couldn't handle today. I don't know what was wrong with it, but I'm not taking any more chances.
                    PlainBill
                    • Dist
                      • Apr 2010
                      • 4
                      #30
                      Thanks.. here they are again.
                      EDIT:
                      and the brand of the capacitors on the board are Su'scon
                      • PlainBill
                        • Feb 2009
                        • 7034
                        EDIT:
                        Su'scon are not known for their high quality. Two caps circled in red are obviously bad. The other caps circled in yellow should also be replaced because A: They are Su'scon; B: At least one of them is vital to the operation of the power supply; C: they are inexpensive and you'd rather not have to open the monitor up again in 3 months.
                        I STRONGLY recommend Digikey, and prefer Panasonic FM caps. If you use Digikey's first class mail option the entire order should cost under $10.
                        PlainBill
                        • Dist
                          • Apr 2010
                          • 4
                          #32
                          Alright, I've atleast got some sort of an idea on what to do now.. ok, so now that I know I need to replace the capacitors, I just need to know what capacitors to purchase.. Do I go ahead and just get the same ones(uf/v) just a different brand? I've attached the same picture but with the capacitors labeled.. Thanks again for your help and time.. I really appreciate it.
                          EDIT:
                          Yea.. I really need help on choosing capacitors because I just went to DigiKey and was looking around when I realized that I should probably wait and find out exactly what capacitors I need.. I know little to nothing about electronics circuitry.. Again.. thank you.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            EDIT:
                            OK, what you have marked up will come in handy when you are replacing the caps. But most of us have better things to d with their time.
                            The next thing for you to do is make a list of the capacitors, showing capacity, voltage, height, and diameter. (You don't have to specify the height of all of them, just the maximum height that will fit.) Someone will then make up a list of recommended replacements.
                            PlainBill
                            • Dist
                              • Apr 2010
                              • 4
                              #34
                              Thank you PlainBill. I understand and I appreciate your time. I will continue when I get off work.. I should have another pic posted soon..
                              again, thank you!!!!
                              • PlainBill
                                • Feb 2009
                                • 7034
                                No picture necessary, post a list Something like this:
                                Height limit 65mm
                                680 uF 25 Volt 10 mm diam
                                820 uF 35 Volt 16 mm diam
                                47uF.....
                                PlainBill
                                • weflyuniv
                                  • May 2010
                                  • 20
                                  #36
                                  I also have a Gateway FPD1975W as well as a Samsung 931BF and a Samsung 204 BW. I scrounged these and others from a local Computer Recycle. I have disassembled all three and each one of them has bulging caps which I intend to replace. I would prefer to follow this forum's advice - Digikey and Panasonic FM caps - but I am daunted by the myriad choices at the Digikey ordering page. I will appreciate any assistance
                                  Ken
                                  Here is what I need to replace all with height limit of 20mm:
                                  Samsung 204BW
                                  820uF 25Volt 10 mm diam - need 5
                                  330uF 25Volt 10 mm diam - need 1
                                  Existing brand - Samwha
                                  Samsung 931BF
                                  820uF 25Volt 10 mm diam - need 2
                                  470uF 25Volt 10 mm diam - need 1
                                  1000uF 10Volt 10 mm diam - need 2
                                  330uF 10Volt 8 mm diam - need 1
                                  47uF 50Volt 6 mm diam - need 1
                                  7uF 50Volt 5 mm diam - need 1
                                  Existing brand - CapXon
                                  Gateway FPD1975W
                                  680uF 25Volt 10 mm diam - need 4
                                  220uF 25Volt 10 mm diam - need 3
                                  470uF 25Volt 10 mm diam - need 2
                                  10uF 50Volt 5 mm diam - need 1
                                  22uF 50Volt 5 mm diam - need 1
                                  Existing brand - Xunda
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    Good for you for snagging these before they hit the landfill. I wish I could do the same!
                                    Hopefully caps are all these monitors need to be fixed.
                                    The easiest way to narrow down your options is to go to digikey.com, type in (search field)
                                    "820uf 25 fm"
                                    and it will show only 2 options. One requires a minimum order of 1000 and the other is 1. So that narrows down the choice. Unfortunately though the Panasonic FM is 10mm x 25mm.
                                    So I change the search to "820uf 25v 20.00mm" and it lists 2 options with a minimum order of 1. So choose Panasonic FC or UCC LXY. These caps are both 12.5mm diameter though and it *may* fit your scenario of the caps are packed closely together with something else.
                                    So if you do the same for all your caps, it should make the options more limited.
                                    --- begin sig file ---
                                    --- end sig file ---
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Ken
                                      Samsung 204BW
                                      Samsung 931BF
                                      Gateway FPD1975W
                                      A procedure for selecting caps is right here. You can try it and see how your results compare to mine.
                                      First we rationalize the list. Then we pick out the parts.
                                      1000uF 10Volt 10 mm diam - need 2 P12353-ND EEU-FM1A102 @$.51 ea
                                      820uF 25Volt 10 mm diam - need 7 P11222-ND EEU-FC1E821S @$1.27 ea
                                      680uF 25Volt 10 mm diam - need 4 P12390-ND EEU-FM1E681 @$.61 ea
                                      470uF 25Volt 10 mm diam - need 3 P12388-ND EEU-FM1E471 @$.51 ea
                                      330uF 25Volt 10 mm diam - need 2 P12386-ND EEU-FM1E331 @$.38
                                      220uF 25Volt 10 mm diam - need 3 P12383-ND EEU-FM1E221 @$.33
                                      47uF 50Volt 6 mm diam - need 1 P12383-ND EEU-FM1E221 @$.39
                                      22uF 50Volt 5 mm diam - need 1 P12927-ND EEU-FM1H220 @$.15
                                      10uF 50Volt 5 mm diam - need 1 P10316-ND EEU-FC1H100L @$.33
                                      7uF 50Volt 5 mm diam - need 1 ??? Are you sure this isn't 47 uF?
                                      When ordering from Digikey, I suggest specifying USPS First Class mail shipping. Most order will be delivered in two days, at a significant savings over Priority Mail or UPS.
                                      PlainBill
                                      • weflyuniv
                                        • May 2010
                                        • 20
                                        #39
                                        I have no experience at this but I assumed it should be not too difficult to obtain replacements without having to deviate from the original size and specs. There doesn't appear to be much if any extra room for these caps and my inclination would be to not diverge from the original size. I must be missing something. Are my choices so slim by limiting the choice of brands or supply house?
                                        Although I have little to no knowledge of electronics I was inspired to try to restore these monitors after reading about bad capacitors and how easy and cheap replacing them can be. I am comfortable to gamble the modest investment in caps and the considerable (for me at as a rank novice) time to do the job carefully. I understand that replacing the caps may not restore function. I am competent to disassemble/reassemble and do fine work but I am hesitant to deviate from the original configuration. As a complete novice I am naturally unsure where it is appropriate to diverge from exact replacement parts. I should say also I am comfortable to take full responsibility for the outcome of applying any guidance and expect no guarantees.
                                        I have had good success restoring computers and putting them back into the community and have a nearly unlimited supply 2 to 5 year old gear. I have many more monitors available and should I have some success with replacing caps on these three displays I hope to develop more capacity to troubleshoot and repair. I hate seeing all this gear go to the landfill and enjoy seeing computers continue to serve.
                                        I appreciate the time and expertise that anyone may offer to assist me.
                                        Ken
                                        PS I see now PlainBill has responded after I posted this. I will study PlainBill's suggestions. Thank you!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Post some pics of the caps that are tightly squeezed together. I did not check any other cap on the list, I just took the first one and tried to give you an idea on how it is done.
                                          Even PlainBill's part number for the 860uF 25V is 12.5mm in diameter above.
                                          You could get creative and put the cap in at a bit of of an angle if they are side by side. You may even see some caps on the 3 monitors that are not installed straight 90 degrees up and down.
                                          Other brands may have caps in the 820uF 25v, but you may have to try other suppliers who carry brands like Rubycon or some other.
                                          I started "capping" just 5 weeks ago and so far I have fixed 5+ and waiting for caps for 3 others.
                                          If you have not soldered, there are videos on youtube on how to do it as well as a FAQ here.
                                          My favourite solder video is
                                          http://www.youtube.com/watch?v=I_NU2ruzyc4
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            07-13-2025, 04:41 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                          • mobotest
                                            Acer S231HL LCD LED Monitor - No power then works after unplugged for a month
                                            by mobotest
                                            Monitor:
                                            Acer S231HL LCD LED
                                            Adapter:
                                            Delta Electronics ADP-40PH 19V 2.1 AC/DC
                                            Symptom:
                                            No monitor power LED light. Monitor did not turn on.
                                            Adapter measured 18.92V at adapter barrel connector.
                                            Then after a month of leaving monitor unplugged, monitor started working again yesterday.
                                            Adapter still measures 18.92V.
                                            Questions:
                                            1. Is 18.92V output within spec for a 19V adapter? or is it a sign of future failure?
                                            2. Does the described behavior indicate some component in the monitor that is faulty...
                                            01-16-2021, 03:54 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
