Sony GDM-FW900 Monitor
  • Ziggy925
    • Jun 2018
    Looking at a Sony CRT monitor making these noises and does not turn on. Background noise sounds a little like an electric fan, then it makes what sounds like a metal on metal scraping noise, then it makes a click. The scraping noise and click repeat over and over. Any ideas where to start? I'm thinking this is some kind of shutdown circuit.
  • R_J
    • Jun 2012
    • 9558
    Re: Sony GDM-FW900 Monitor
    There are a lot of posts on this model, what area/board is the sound coming from? power supply, high voltage area?
      master hoarder
      • May 2008
      • 12175
      Oh noes! Sounds like another one of these bit the dust from loosing vacuum. But let's verify that. Remove the plastic back shell/casing on the monitor and also the top metal cover so you can see the boards inside the monitor. Now plug in the monitor and have a look at the back of the CRT tube neck (the thin glass part that extends all the way to the back of the monitor) - do you see blue arcs in there? What about spark gap SG902 on the D-board (the board with the flyback transformer and big fat red wire coming out of it and going to the front of the CRT tube). If yes, CRT most likely has lost vacuum, hence the arcing.
      If you can, post some pictures of the monitor.
      Here's my post on this monitor of that issue:
      https://www.badcaps.net/forum/showpo...3&postcount=22
        by momaka
        03-15-2023, 10:17 PM
      • FZG
        Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
        by FZG
        Hello there, helpful forum people!
        I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
        On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
        The original part...
        05-10-2023, 11:54 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
