VA912b turns on then goes black (green light still solid green)
  • angryllama
    • Mar 2009
    I have a VA912b. I had it for about 2 years.
    My problem:
    This morning I came to my computer to check up on my E-mail. The light was orange (sleep) so I moved my mouse. The monitor turned on (green light) then I could see my screen perfectly for about 1 second then it went black. I was confused so I moved my mouse some more but it didn't work.
    I turned it off and on about 3 times and then it stayed on until about a few hours later. It happed again so I repeatedly pressed the "2" button (honestly, I don't know what this button does, maybe it changes the monitor to a diffrent channel?) next tot he power. It fixed faster than the first time.
    However, the problem happed AGAIN about 1 1/2 hr after that. However this time, It would not stay on. I called Viewsonic and their crummy support person said "honestly I have no idea what I am doing, I just ask if people want to send their monitors in and fix'd for a price". I just hung up and resorted to my huge CRT that takes up 75% of my work space.
    RECAP:
    When the monitor is turned on, I can see picture perfectly for about 1 second then it goes black, like it engaged sleep mode. However, the light isn't orange. It is still green as if it is still working. I am confused.
    Any help would be appreciated.
    -Llama
  • PlainBill
    • Feb 2009
    • 7034
    Re: VA912b turns on then goes black (green light still solid green)
    I think this is a typical 'two seconds to black' problem. The inverter (which powers the backlights) turns them on, then a few seconds later decides a fault condition exists and turns them back off. The cause could be one or more bad backlights, a bad inverter, or even a bad power supply.
    The repair will require disassembling the monitor to reach the electronics inside. This can be only slightly more difficult than gassing up a car on some monitors, on others a team of engineers from heck toiled for weeks to design latches that would baffle Houdini. Once the monitor is open look for bulging caps.
    Once the problem is identified some soldering will be required. If the problem is bad caps in the power supply, expect replacements to cost $5.00 - $10.00. CCFLs (backlights) are more expensive ($5-$10 each) and require extensive disassembly. Are you capable of handling the repairs yourself?
    I will warn you that the rush of successfully repairing a monitor is very powerful. Mature adults have been known to high-five everyone in sight.
    PlainBill
    • angryllama
      • Mar 2009
      PlainBill
      HAHA that last line made me spit my water out.
      I will look into the monitor. But once identified, do I cut out the bulges or whatnot?
      -Llama
      • FIXITNOW
        • Jun 2008
        • 128
        viewsonic VA912b tip
        Flashing green light. No picture
        three bulging caps were 470uf 25v reading between 3 and 7 ohms esr. The big 100uf 400v cap had a slight bulge but was open all replaced
        • PlainBill
          • Feb 2009
          • 7034
          -Llama
          Bulging caps are always defective, non-bulging caps may be defective. Certain brands of caps are notorious for failing. Given the low cost of high quality replacements I always replace all of them if there is any reason to suspect any. This does require using a soldering iron.
          PlainBill
          • judamex
            MacBook Air 820-00165 turns on But no green and orange light, not charge
            by judamex
            MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
            03-06-2025, 03:55 PM
          • cajoeg
            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
            by cajoeg
            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
            02-10-2025, 04:01 PM
          • MOSSEP
            Monitor Audio RSW12 - Green light, but no sound
            by MOSSEP
            Hi
            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
            I have already tried replacing all of the...
            01-26-2025, 08:33 AM
          • MOSSEP
            Monitor Audio RSW12 - Green light but no audio
            by MOSSEP
            Hi
            01-26-2025, 08:18 AM
          • lcdcaps1
            820-2610-A Sys onewire help, no green light. Please help from the gurus
            by lcdcaps1
            Hi
            I have an 820-2610-A motherboard that has no green light.
            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
            The sys onewire circuit on this model and others is more involved
            I was hoping if anyone knows about this and how it works, can reply and let me know
            I know this is an old model but I am sure there are people who still works on these or knows about them
            I get 1.1v on the C7771 capacitor and will replace...
            11-06-2023, 01:28 PM
