Planar PL1910M LCD will not power on
+ More Options
Posts
  • samnabass
    • Feb 2009
    • 8
    Hi to all.
    This monitor has been driving me nuts for the past two days and I just can't figure it out so i came in for some help.
    The main problem is the monitor will not turn on just a flashing LED on the ON button.
    The back lights were checked to be OK
    All the caps checked ok with and ESR Tester.
    All the diodes checked OK – Desolder one leg and test with a smart tweezers.
    MOSFET Tested Ok.
    Resolder all the joints on the back side.
    And still no go – so I figured maybe I should try to power it from an external power adapter but there are no marking on the board to which pen is which. So I plugged in a couple of extra back lights to the board. Flipped it upside down and fired it up and start poking the bins I found the +5V / +12 / Ground / On / Of while doing that I accidentally jumped the pins marked on the attached image A&B and the back lights come on and stayed on – tried to trace the connectors to the Video board but that's almost impassible.
    All the caps on the video board checked ok too.
    Any ideas ???
  • mladen82
    • Mar 2009
    • 39
    • Montenegro
    Re: Planar PL1910M LCD will not power on
    if dc voltages +5V and +12V are fine and if are regulated voltages on main a/d board (3.3V or 1.8V probably) are fine too, problem is probably in mcu (or his eeprom) as led flashing, however check for possible shorts (smd capacitors) on main board or even shorts towards lcd panel electronics
    • samnabass
      • Feb 2009
      • 8
      Hi, Thanks for the info - i did check as much as i can with no luck - i spend too much time on this board and i think it's time for it to be recycled.
      Take Care.
      • EGuevarae
        • Nov 2008
        • 1336
        Originally posted by samnabass
        Hi to all.
        MOSFET Tested Ok.
        Any ideas ???
        Looks more like a Hanns-G than a Planar.... look at this thread : https://www.badcaps.net/forum/showthread.php?t=6695
        Did you check the LCD without the LCD connected to the VBoard to see how the power LED behaves?
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • stneargd
          • Apr 2008
          If the led is flashing green and amber, the unit needs reset. I have purchased 3 of these units with this issue and all worked after resetting.
          Here is the link to the reset procedure:
          http://marsbox.com/blog/howtos/plana...d-monitor-fix/
          • pfjoe
            • Nov 2009
            strneargd ... you are my new hero ... thanks!!!
            • sceva
              • 196
              I just fixed a Planar PL1911M with the same problem!! Thanks for the link.
              • DigitalStone
                • Jan 2011
                • 39
                Same here. Thanks for the link. Wish I had found this before I took it apart.
                Works great now.
                • jfarrell
                  • Feb 2011
                  OK so this planar was fixed with a reset...amazing....
                  now my question is...
                  How many other monitors allow a similar reset, to get them going again.
                  ( is planar the lone dog? )
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • DynaxSC
                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                    by DynaxSC
                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                    03-10-2025, 12:27 PM
                  • Superbee_dad
                    Sharp 80” long short flash backlight error - Help
                    by Superbee_dad
                    Hello Sharp TV experts
                    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                    01-24-2025, 11:51 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
