Benq G2255 doesn't power on - amber power light when plugged in - part 2
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Re: Benq G2255 doesn't power on - amber power light when plugged in - part 2
    Ok, so bad news, the original flash chip is identical to the .bin file I had downloaded and there is a verification option of the chip and it reports perfect.
    I programmed some of the new chips (left the original intact) and all chip contents are the same.
    So the problem lies elsewhere.......
    I think I found the EEprom file on a Russian website 2k bytes long.
    http://monitor.espec.ws/section33/topic250038.html
    Should I check the Eeprom see if it compares?
    • will62
      • Dec 2016
      • 229
      • usa
      #62
      Well, that is bad news. You might as well check the eeprom. If all is well there, it may go back to the low ohms to ground on your 1.8V/3.3V.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 940
        Ok Will, so here's the scoop. I checked the Eeprom and read the file and saved it. Compared it to the one I downloaded, and although it starts the same, the rest is almost all different...many many differences.
        So either the eeprom file I downloaded is not the same version (although the flash file was the same) or my eeprom is corrupt?
        What do you think I should do? I am attaching a copy of both files (my eeprom file and the one I downloaded) in zip format because I can't upload a .bin file.
        I checked my eeprom chip and I get the following message: "Chip main memory and buffer same", whatever that means!
        Attached is a comparison of both files.
        • will62
          • Dec 2016
          • 229
          • usa
          #64
          I can't make anything out of the differences. I did notice that the new file is almost twice the size of the old one. Do you have one of those "24" eeprom chips (sufficient size) on another board, that you could pull and copy the new file to? Until you know more, I wouldn't erase what is on that eeprom.
          edit:
          Ok, got both open in Visual Studio. The new one is not twice as large, but is larger. Did you notice that some of the 16 Bytes of data are the same, just at different addresses? They both also skip down to about 600 and pick up with more data. There's nothing here that I can see that changes what I said above.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 940
            Ok, found a 24C16WP from a scrap board - erased it and put the other eeprom file on it. Need to resolder the flash and the new eeprom and give it a try. I'll try and do this tonight, however the movers came in today for my basement water damage and everything is upside down, including my opened monitor that I had stashed away during the construction work. Will keep you posted.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 940
              Did the test with the new eeprom and still same result, as power is applied the amber light comes on and the switches have no effect. So not flash and not eeprom. Should we go for the big TSU ??
              • rddube
                Aspiring Expert
                • Jun 2013
                • 940
                Looking at the main board and taking readings here and there and I found 2 caps that I get a 15 ohm measure, photo attached.
                • will62
                  • Dec 2016
                  • 229
                  • usa
                  #68
                  I need to look back on the circuit, but those look like filter caps for the 5V to the t-con. We didn't have low ohms to ground on the 5V line, did we?
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    No, on the 5V rail I get 575K ohms rising.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 940
                      Hey Will, when you have a chance take a look at this Russian thread. One guy says he changed the "prots" (translation) and seems to go on and say he changed the TSU and it fixed it.
                      http://**************/forum/54-31467-1#283782
                      • will62
                        • Dec 2016
                        • 229
                        • usa
                        #71
                        It will only let me read the first few posts w/o logging in, and I don't want to register for 1 post. Can you paste the translation of the post that discussed the resolution to the problem?
                        Edit: Added diagram for panel_on and lcd_5V_aware
                        You can remove those caps with low resistance to ground to verify, but I'll bet the low value is from the TSUM chip lcd_5V_aware. Follow attached circuit.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 940
                          Here you go, the whole post. Towards the end there is a user called DDD that talks about prots ?
                          • will62
                            • Dec 2016
                            • 229
                            • usa
                            #73
                            Kind of a rough translation, but the way I read it, is that he had seen another monitor with the same issue, and fixed it by replacing the TSUM chip. He substituted an NHJ for the NWHJ version of the chip.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 940
                              Yes, that is kind of what I thought too. Well I ordered a TSUM chip on Aliexpress....I guess that looks like the next logical step?
                              • will62
                                • Dec 2016
                                • 229
                                • usa
                                #75
                                I think that's the best move. You going to practice your drag soldering on a scrap board?
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 940
                                  Hi Will. I already did and am getting pretty good at it....I unsoldered and soldered back a Winbond chip that is pretty much the size of the TSUM. My only concern is when I remove the TSUM, there are very little ceramic capacitors right beside it that my blow away!
                                  I bought aluminum tape and am going to mask around the TSUM when the time comes.... I'll keep you posted in about 3-4 weeks'
                                    • 12192
                                    • U.S.
                                    #77
                                    Cool thread, very interesting, I hope you guys solve it.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 940
                                      I have 2 boards (scrap boards) that come from a Dell E207wfp, copy of service manual attached.
                                      The main chip looks like the same footprint as the TSUM, but I can't identify which chip it is as it has a heatsink solidly glued to it, that might damage it if I try and remove it.
                                      The board is a 715g2089-1 and in the schematic in the manual, they say U401 which corresponds but don't say what chip it is. How can I find out if it is a TSUM or not?
                                      If it was, I could do my test immediately.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 940
                                        Thank you. Actually Will62 is the brain behind this and I am the executor. Without Will62 wouldn't have gotten this far. I have learnt a lot doing this.
                                        Don't forget there is a part 1 to this thread where I think we solved the power board inverter problem. This thread is about the main board.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 940
                                          Ok, I succeeded in getting the heatsink off and even though the glue is still there, I think it is a GM5766 (I only see the beginning GM57...so I assume that is what it is.
                                          Don't suppose it could be a replacement for the TSUM? Copy of the datasheet attached.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • Noodneek
                                            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                            by Noodneek
                                            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                            08-30-2024, 12:52 PM
                                            09-06-2024, 05:59 AM
