Dell E153Fpc bad C922 cap.
+ More Options
Posts
  • hobbzilla
    • Feb 2009
    As a background, I am experiencing the same exact issue detailed here:
    https://www.badcaps.net/forum/showthread.php?t=5315
    and here:
    http://www.electronicrepairguide.com...or-repair.html
    Capacitor is visibly bulging at the top and the PCB is discolored in a 1.5" radius around it's position.
    That being said, I have never replaced a cap before and I believe I have now damaged the PCB. Basically, I have improperly removed the capacitor and have damaged the embeded foil / trace. While pushing & pulling on the capacitor, the old solder apparently did not get hot enough and tore off taking with it the foil/trace that it was fused to. On the backside of the board, the hole is exposed and you can clearly see that the foil is not coming into contact with the lead port / hole which would mean that the replacement capacitor would not make contact unless action is taken. You can _barely_ see the edge of the foil from the trace just outside where the old solder point is/was.
    My question is: Given the knowledge that the trace is extremely wide and is still intact (so it appears), is it kosher to simply run some additional solder ontop of the board to a connecting solder point on that trace? or is that bad, bad, bad?
    My only other choice would be to hope that the solder would make a good connection to the *barely* visible section remaining.
    well... that or buy a new one ($40 - ouch! & not worth it)
    http://www.lcdrepair.us/e152-e153fpc...ter-power.html
  • Toasty
    • Jul 2007
    • 4171
    Re: Dell E153Fpc bad C922 cap.
    is it kosher to simply run some additional solder on top of the board to a connecting solder point on that trace?
    In a nutshell- maybe/possibly/say your prayers...
    A clear picture of the damaged area will make it simpler to answer.
    Toast
    veritas odium parit
    • Krankshaft
      • Jan 2007
      • 2328
      Cmon toasty I thought you knew better than that.
      Don't give up until the board is a steaming pile of slag .
      Get a razor knife (straight razors work best) and scrape the mask off of the remaining trace (the line of copper that connected to the trace you lifted). Tin the now bare copper with solder.
      Insert the new component through the hole and bend the leg over the trace and apply your iron over the lead to solder the leg down. Trim the excess cap lead past the solder with side cutters as usual.
      A very basic technique when you've goofed up. Jumper wire would work too but it wouldn't give the cap a firm mechanical connection.
      This is why you use desoldering braid on single sided boards . It would have sucked up all the solder so you could just pull the cap out.
      It takes some time to learn how to use it it's just like learning to solder practice makes perfect. But it's worth it.
      Also you should be replacing all of the secondary caps or at least all of the caps of the same brand that failed.
      I have destroyed a few traces myself but it was because of horribly thin copper used on the PCB to cut costs thanks China.
      • Toasty
        • Jul 2007
        • 4171
        No, no, no. That's the governments work ethic - If it ain't broke, fix it 'til it is....
        I was hoping to get a picture of the area to show him what to do. Just as you said in your post, but with pictures. Since he's already mangled the unit, (from his description, rather nicely, I might add ) I wanted to go slow.
        But, no, no, no. You gotta run in here, yellin' directions.
        Bend this, solder that jumper here, there, everywhere. I'm amazed you didn't recommend a spot welder!
        Oh, I'm havin' some fun toooo-dayy!!
        MORE COFFEE!!!!!! The cat and I are gonna War Game!
        I'll wait on the pics there, hobbzilla...
        Toast
        veritas odium parit
        • NxB
          • Feb 2009
          • 1595
          I tend to break ribbon connectors. I've also melted things with the heat gun. This not so much. I have pulled the little metal rings out of dual sided boards when desoldering. And I hate it when the braid refuses to clear that last bit of solder from the hole and I'm trying to put new parts in.
          • Toasty
            • Jul 2007
            • 4171
            veritas odium parit
            • Kemer
              CMOS battery holder solder pad trace
              by Kemer
              I will add a photo of HP 15 laptop mainboard. The positive side of CMOS battery holder solder pad has been broken. What I want to ask is, the trace of positive pole. If you look at the photo, you will notice red color "A" and "B" letters for two different shades of blue.
              Anybody help?...
              12-20-2024, 02:41 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
              Acer Chromebook C922-K04T Chromebook 314 Specification for Upgrade or Repair
              This specification for the Acer Chromebook C922-K04T Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C922-K04T boardview and C922-K04T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              09-07-2024, 03:10 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
