RCA LED65G55R120Q TV Set Power issue?
  • mwbrown1979
    • Dec 2017
    • 3
    Hi all. I read through a previous thread regarding this same set, I'm hoping to get some confirmation that I'm on the right track. The set will flash once every 3-5 seconds when powered on. No indicator light, neither standby nor power on. During this 3-5 second cycle the screen only displays 2-3 colored horizontal lines. Will not power on. I've confirmed 120v at the power board, only reading 3-3.5v going out of it. No indications of blown capacitors from what I can see, but I am far from an expert. I read in Mr. Martin's troubleshooting guide I should have 5v standby, etc. With a reading of 3-3.5 do you blame a faulty power board? I really want this set going but I can't throw parts at it blindly Any guidance would be greatly appreciated!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: RCA LED65G55R120Q TV Set Power issue?
    Need good clear straight on pictures of back of tv with cover off and each board.
    • mwbrown1979
      • Dec 2017
      • 3
      here goes..thank you!!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
        Format:
        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
        1 - XXXXXXX - XXv - XXXv
        2 - XXXXXXX - XXXv - XXXv
        3 - XXXXXXX - XXXv - XXXv
        4 - etc.
        • bkdadto3
          • 21
          • usa
          I am going to jump in here and say, that I have this exact setup and I am not able to get power to come on but my voltage readings confuse me. Here is what I get at the power board capacitor: 166.9 vdc
          At con2 I get
          Pin
          1 EMPTY
          2 EMPTY
          3 GND
          4 GND
          5 13.23 V THIS IS LABELED AS 12V
          6 13.23 V THIS IS LABELED AS 12V
          7 GND
          8 13.23 V THIS IS LABELED AS 12V
          9 GND
          10 GND
          11 GND
          12 5.1 V THIS IS LABELED AS 5V
          13 5.1 V THIS IS LABELED AS 5V
          14 5.1 V THIS IS LABELED AS 5V
          15 4.46 V THIS IS LABELED AS PS ON
          16 5.09 V THIS IS LABELED AS 5 VSB
          17 4.70 V THIS IS LABELED AS ADJ
          18 0.4 mv THIS IS LABELED AS BK ON
          Trying to figure out if this is a main board issue or a power board issue.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Do you see an image if you put a flashlight up to the screen?
            • bkdadto3
              • 21
              • usa
              No, no video, no led nothing at all.
              • bkdadto3
                • 21
                • usa
                This is the state all of the time, all of these voltages are present but no leds are lit anywhere and there is no ability to turn on the tv.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  What is voltage on ps_on when you push power button and when in standby? 18 0.4 mv THIS IS LABELED AS BK ON maybe backlight. Other voltages seem OK
                  • bkdadto3
                    • 21
                    • usa
                    The voltage is 4.46 v with the switch depressed and when it is not. The power on button makes no difference at all, there are no power leds even lit up on the tv to indicate standby power.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      What is voltage on ps_on when unplugged from main board?
                      • bkdadto3
                        • 21
                        • usa
                        zero volts
                        0.0 v
                        • bkdadto3
                          • 21
                          • usa
                          Still my main cap is only seeing 167.9 vdc
                          • CapLeaker
                            Leaking Member
                            • 8296
                            When the tv goes into test pattern, check the main filter cap voltage and the 24V rail. It sounds like a bad main board to me, but first verify voltages on the PSU. If push comes to shove, disconnect everything from the PSU and force it on. If that PSU checks out all right, then it is a main board problem.
                            • bkdadto3
                              • 21
                              • usa
                              Well, the person decided to take it to their brother to be worked on. I may never know the root cause. Thanks for the help.
                                PS-ON is present but you still have only 160Vdc on the filter cap, it shoould be 380~400VDC because the board has PFC Voltage booster circuit, you need to get the PFC circuit working first.
                                How much experience do you have troubleshooting down to component level and SMD reworks?
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • justice171
                                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                  by justice171
                                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                  1. Verified that all critical voltages are present:
                                    • 3.3V and 5V are always present if DC is plugged.
                                    • 1.8V on the BIOS chip is present.
                                  2. Checked the power button functionality:
                                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                    • Confirmed connectivity is intact, ruling out issues
                                  11-26-2024, 12:39 AM
                                • claws77
                                  lenovo flex 5 14itl05 power sequence issue
                                  by claws77
                                  hi guys, my motherboard will not start no matter what
                                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                  but rest nothing happens no sign of life.
                                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                  i have no knowledge of motherboards ....
                                  10-20-2024, 02:48 PM
                                • yaya3gmax
                                  Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                  by yaya3gmax
                                  Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                  Symptoms:
                                  • Laptop works normally on a pre-charged battery.
                                  • Battery does not charge when adapter is connected.
                                  • Without battery:
                                    • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                    • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                    • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                  08-21-2025, 07:16 AM
