Repairing a DELL 2408WFPb
  • respenica
    • Oct 2017
    • 33
    • Portugal
    the monitor did not power up.
    This repair was different from all the others. Not the caps this time!
    Power supply was good. I had a clue that the problem was a bad solder joints in the logic board. So, I made the reflow of the logic board mainly of FLI30336 chip.
    I had to remove the heat-sinks that were solder to the PCB.
    This reflow worked and the monitor was working again.
    But, this repair is not reliable. Some weeks later the monitor failed again.
    I try to make the same repair but in this second attempt I damage the front panel flat cable connector in the logic board!
    Now I have to manage to make a patch.
    Hope this helps someone.
    Does anyone have the schematic for this logic board?
    Regards
    Roberto
  • respenica
    • Oct 2017
    • 33
    • Portugal
    Re: Repairing a DELL 2408WFPb
    in attach a picture with the connector damaged.
    Roberto
    • Borse2008
      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
      by Borse2008
      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
      • There’s
      07-15-2025, 04:55 AM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
      by DanPoka
      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
      02-15-2025, 05:05 AM
    • ChristianBr01
      Dell 34 inch U3419W Monitor with thin stripes on partial screen
      by ChristianBr01
      I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
      This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
      This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
      Does someone have seen this before?...
      05-23-2025, 06:06 AM
