lg W2246
  • rop12770
    • Mar 2010
    • 22
    • Portugal
    lg W2246
    Hello
    I have this LG that gives image for 1 or 2 seconds and then goes dark, but power led is on (I have checked this thread already: https://www.badcaps.net/forum/showthread.php?t=14144).
    Checked all the capacitors (I even swapped the 25V and 16V ones) and problem still remains..,
    I have used a laptop LCD to rule out the lamp problem (still the same)
    What else can it be?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: lg W2246
    Check out the stick thread related to this issue: https://www.badcaps.net/forum/showthread.php?t=10419
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Re: lg W2246
      Originally posted by rop12770
      Hello
      invertor transformer?
      • rop12770
        • Mar 2010
        • 22
        • Portugal
        Re: lg W2246
        I have tested everything and all seems fine....
        The transformer, all caps (including the little blue ones, diodes, etc....)
        I'm about to quit.....
        • vestaviascott
          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
          by vestaviascott
          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
          Here's what happens:
          1) Power on
          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
          3) Blue status light flashes for appx 4 minutes...
          07-29-2020, 06:08 AM
        • AJ847.63e
          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
          by AJ847.63e
          Hi All.
          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
          09-18-2023, 06:42 PM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • mikey5791
          Help on Samsung Syncmaster T220 dead ccfl lamp
          by mikey5791
          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
          10-18-2020, 03:17 AM
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
