Proview Pro576 (Model 568) delays to start when cold.
  • EGuevarae
    • Nov 2008
    • 1336
    I have a Proview LCD 568 that has no bad caps on a visual inspection, but it delays to start on cold. Checking my notes, all the caps are su'scon (in the bad list), so maybe your problem is similar to mine. I had this since the beggining of the last year, and I had forgotten about it when I was cleaning this morning and found it. I didn't open it again, but went straight to my notes. On them, I saw that (as mentioned) all the caps are su'scon. It has:
    07 - 220uf 16v
    03 - 22uf 16v
    07 - 100uf 16v
    All are Su'Scon @ 105C (no series. I was not aware of such things back then).
    The problem with the monitor is : When it is turned on after being off for a while, the power led starts blinking and if you press the On/Off button, it won't respond. After a while, the screen starts up and you can turn it on/off and it works perfectly, until you let it off for a while (an hour and a half is enough). If I disconnect the ribbon from the VBoard to the LCD Panel, the power led goes to solid green as soon as you press the ON button, even if cold. The behavior is present only with the LCD panel actually connected to the VBoard (according to my notes). The PSU is an external 12v 3.5a brick, and besides the VBoard, there is only a standalone inverter (not same board). I have tested the inverter using a 12v PSU (a cable adapter from an unused ribbon and an extension for a molex cable of a n ATX PSU) and it starts OK everytime. Any suggestion?
    Will dissasembly the LCD tomorrow and will take pictures to post if necessary.
    Eduardo
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Proview Pro576 (Model 568) delays to start when cold.
    It sounds like one of those caps is responsible to charge up to a point to turn on a transistor and for whatever reason after a full discharge that cap is taking too long to charge up.
    Might be the cap itself or might be a degraded resistor or diode in it's charge/discharge path that is either restricting the charge path or opening up a discharge path that shouldn't be that large during start up.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I'm working on a Proview power board/inverter out of a TV right now.
      I'm not real impressed.
      It is silk screened for two fuses and both fuses are missing with soldered in jumpers installed in their place.
      - Dr Seuss
      • FIXITNOW
        • Jun 2008
        • 128
        • FIXITNOW
          • Jun 2008
          • 128
          I HAVE KNOW THE PSU external 12v 3.5a brick to be faulty voltage kept droping so i replaced it
          • Wizard
            • Mar 2008
            • 2296
            Don't keep using the unit till capacitors are replaced and install fuses.
            Cheers, Wizard
            • EGuevarae
              • Nov 2008
              • 1336
              Cheers, Wizard
              That was my original plan, but the caps I have will not clear the tight space. I will post a pic of the board so you can see them. They have no vents, and all of them look OK. I suspected when I checked my notes, that the panel turned on after a cap charged fully, but which one (or ones)?
              My 2nd idea was to change them one by one until I found the culprit instead of buying the whole set from Digikey (I would really be happy to change only the bad ones instead of all, just for the sake of knowing which were bad)
              • GeForce GT1050
              • EGuevarae
                • Nov 2008
                • 1336
                Originally posted by FIXITNOW
                I HAVE KNOW THE PSU external 12v 3.5a brick to be faulty voltage kept dropping so i replaced it
                One of the first things I did. I took a good known, working brick from another Proview, and same result.
                • GeForce GT1050
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Here are some pics. You can see the Su'scon brand, and the size of the caps.
                  • GeForce GT1050
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    What is with the missing cap with a circle around the spot?
                    Did you pull that or is one just missing there?
                    - Dr Seuss
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      It was not there (it looks like never was anything there) when I opened the LCD the first time. But there was almost shorted by solder, so I did that and circled it (but I don't remember why the circle ;-)
                      • GeForce GT1050
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        It just looks like some cap has been removed there in the pic.
                        Disturbed solder and a circle.
                        - Dr Seuss
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Yeah, but believe me, it was nothing there. There are many silk screened components including a ribbon-like screen that reads LVDS (never heard of LVDS outside of SCSI HDDs ....), but nothing is present.
                          And in the end, it was a cap, or all of them. I tested with the caps I had to see if it will work before ordering from Digikey, and guess what? It worked right since the first time after the recap. Now I just have to order, wait for the order and solder the ones that will be finally there, and that's it.
                          Now I am a happy owner of a Proview 568. See the pics of the "after".
                          • GeForce GT1050
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Look, I found someone with my same problem, but on a 17". Now I'm stuck looking for 5mm tall caps.
                            Xerox Thread
                            • GeForce GT1050
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Glad you got it working it's times like that I'm glad I have an ESR meter.
                              The warm up working is a common symptom of a cap whose ESR has gone up as temperature rises ESR drops so once the monitor was warm the caps ESR was low enough for the monitor to function.
                              However when it was allowed to cool the ESR rose again causing the problems you encountered.
                              Whenever a problem is temperature related like that I always go for the caps first.
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                I'm learning new things in this forum. Honestly, I received basic electronics instruction as part of my Computer Maintenance & Repair course 15 years ago, and beyond what components are/do, and soldering skills I acquired when I made (a lot of) null modem cables. But apart from that, only reading and browsing on the forums gave me the "I can do it" idea, and thanks to people like you (PCBONEZ, Krankshaft, Wizard and all the other users/members who contribute here whose names escape my troubled mind right now... I might have cap problems myself ) I am learning. I have saved so far like 15 LCDs from the landfill, and I'm proud of that. And I'll be prouder if I can find those 5mm caps.......
                                And yes, an ESR meter should have saved lots of time & frustration , but then again, all Su'scon would have to go anyway for the repair/recap to last, or am I wrong?
                                • GeForce GT1050
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I finally figured out how to get Mousers search to kick that back but I forgot who asked.
                                  You can get 5mm tall 85C in 22uF and 100uF in Xircon L Series at mouser.
                                  http://www.mouser.com/Search/Product...nIWGBVXQ%3d%3d
                                  http://www.mouser.com/Search/Product...Xm8vRJ0w%3d%3d
                                  L Series:
                                  https://cdn.badcaps-static.com/pdfs/...e75ba3d0e2.pdf
                                  If you can squeeze in 7mm you can get the same in 105C Xircon MLRH series.
                                  http://www.mouser.com/Search/Product...H2nu4UdQ%3d%3d
                                  http://www.mouser.com/Search/Product...agTxckjA%3d%3d
                                  Xircon MLRH series data sheet shows a 7mm tall 220uF 16v but mouser doesn't list it.
                                  https://cdn.badcaps-static.com/pdfs/...32fd3c9b57.pdf
                                  - Dr Seuss
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    I ran into those (first link) but as they were 85c rated and the original were 105c, I didn't pay attention to them (I searched Digikey, and then Mouser). But now that I think about the issue, as the power supply is external, and the inverter is on a separate board, I guess heat would not build up that much, and you can use 85c. Also, as the board is feed 12v 3.5a, I think I can safely use 16v caps. I know that you should go to same V rating or higher, but in this case, 12v is the only voltage used (well, there is 5v too, but it is safe with 16v also), so you can go to 16v and have room for the unexpected (a 4v tolerance). Am I right?
                                    • GeForce GT1050
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Actual circuit voltage + ripple voltage must be less than cap's rated voltage.
                                      As long as it is you are okay on that.
                                      If there is an SMPS section on the board then the voltage (or some of them) may be higher than what it's feed. If there is no transformer you are probably okay but it's still best to check with a meter to be 100% sure.
                                      - Dr Seuss
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Oh DUH!
                                        You posted photos...
                                        I see a transformer in there.
                                        I would check voltages.
                                        - Dr Seuss
                                        • Mirenia
                                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                          by Mirenia
                                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                          If this happened once, then the laptop only runs for a few minutes until restart.
                                          This happens regardless while staying in windows or uefi or in a linux environment.
                                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                          01-05-2025, 05:15 PM
                                        • Sanjit Keskar
                                          Laptop mouse & KB NOT available on power option restart but available only when laptop is cold booted using power button
                                          by Sanjit Keskar
                                          I have this inexplicable problem from yesterday
                                          Each time i start my laptop by pushing the physical power button in, the laptop keyboard and touchpad are available to me for use when the system has booted to the desktop (I can enter the bios by pressing on F10 too) irrespective of whether the laptop is powered by the AC adapter or the battery. This is normal behaviour
                                          BUT NOW FOR THE ABNORMAL PART
                                          However, when using the laptop normally, if i choose restart from the power options, the touchpad and mouse are non-functional when the system has booted to the...
                                          06-06-2024, 10:35 AM
                                        • foxer
                                          Sony AV1010, basically works but heatsink is cold, resistors overheating
                                          by foxer
                                          Weird stuff.
                                          I press power on this receiver, I hear the relay click, I can play music and get radio, everything apparently works but not really. The big heatsink stays cold to the touch, the small heatsinks to the two voltage regulators on the mainboard get super hot, and there are two overheated brown areas on the mainboard with an identical pattern (circled in red), centered on the components on each side of the big capacitors (removed in these pictures). Those last components, of course, also get burning hot.
                                          So...I spent the week with my novice skill trying to locate...
                                          06-19-2023, 07:54 PM
                                        • ictc
                                          Lenovo IdeaPad S145 boot when cold than crash after feew minutes
                                          by ictc
                                          I received this laptop, which initially boots into Windows normally, but after a few minutes, the system freezes with no display and no response except for power button. When this happens, power consumption rises to about 1A (without the battery connected), and the CPU becomes noticeably hotter compared to when the machine is operating normally.
                                          I have already tried removing the additional RAM module, which initially showed some promise, but the issue persisted after a reboot. I also attempted replacing the BIOS, but this did not resolve the problem.
                                          When the system crashes,...
                                          01-31-2025, 11:29 AM
                                        • SuperAman
                                          Hitachi Refrigerator R-Z270AUN7KV not cold.
                                          by SuperAman
                                          Hi, I have a Hitachi Refrigerator R-Z270AUN7KV. The fridge is on the bottom and the freezer is on the top. My problem is no matter what setting (1-9) the freezer is, the fridge is not getting cold but the freezer is always cold. I have tried all combination of settings for the fridge (Min, Mid, Max) but nothing. Fridge is always hot now. Before it would sometimes do this but now always fridge is hot. I believe the service center peeled some of the foil from the thermostat and that seemed to help a few years back. I replaced the thermostat recently and it worked off and on for a few weeks but now...
                                          10-29-2020, 02:01 AM
