Dell 1703FPT LCD Help
  • kenzo42
    • Jan 2009
    • 8
    I have a Dell 1703FPT monitor and one day it just went blank. Switched to new VGA cable and DVI cable. No avail.
    Symptoms:
    1) When plugging in, it displays a scrambled image (see attached pic) rotated 90* CCW.
    2) Monitor glows along the edges but no display
    3) Green power button stays lit and cannot be turned off. Monitor can't be turned off either.
    4) With VGA cable unplugged, it doesn't display anything like "monitor disconnected". Just a blank screen w/ glowing edges.
    5) I've tried it on 2 other computers. They don't display either.
    Another note, I tried DVI and VGA and neither works. Same result.
    Opened it up last night and didn't notice any buldging caps or broken traces either.
    Any ideas? Inverter? Bad cap? Thanks.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Dell 1703FPT LCD Help
    I don't know about the glowing edges, but the inverter doesn't have to do anything with the rotated/scrambled image. The video/main board would be my first guess.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
