Dell FP1905 ultrasharp
  • Ragnarok
    • Apr 2008
    It's the uk version anyway.
    After getting some irritating problems with the monitor. About a year and a bit ago the built in usb hub stoped working. just a week out of warenty it's started taking an age to come out of stand by when cold and the power light going out while this happening. It got progressively worse untill I'd literally have the dell logo appear and a blank display untill it warmed up, When unpluged and pluged in again it would come back to life but it was taking nearly an hour to happen.
    I managed to get into it and low and behold there where 2 bulging capacitors. They are Samxon 1000uf 10v 105°C GF series capacitors. I managed to butcher 2 lelon 1000uf 35v rxk 105°C from an old dead satellite receiver's PSU to get me up and running again and temporary replacement. Everything is working perfectly again and instantly.
    I realise this thing runs pretty hot and Lelon have a bad rep. I understand Samxon have a good reputation and I think they have run in this monitor for at least 20,000 of use so have probably served there specified life. What's the ideal replacements for these caps and possibly the others which where all Samxon GF series? I'm thinking replace the lot too save having to open it up again if others fail.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Dell FP1905 ultrasharp
    Look up Panasonic FC series on Digikey.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • Ragnarok
      • Apr 2008
      Thank you!
      • Krankshaft
        • Jan 2007
        • 2328
        The Samxon GF series is a known screwup on their part they ALWAYS fail in monitors.
        Other than that series they are a good brand like how Nichicon messed up with the HM and HN series for awhile.
        I had a customer with a Gateway LCD monitor and the GFs lasted a little over a year and a half before hatching.
        Replace all the secondary Samxon GFs and Lelons and you'll be back in business.
        As another member said Pana FCs are the best for LCDs and PSUs they are non-aqueous electrolyte caps.
        Which is good due to the arid high heat conditions in LCDs and PSUs.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
        • lalle-
          Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
          by lalle-
          Hello!
          I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
          [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
          I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
          The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
          I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
          08-11-2024, 02:01 PM
