LG E1960s firmware
  • boyebaran
    • Sep 2015
    • 247
    • iran
    LG E1960s firmware
    hi
    firmware E1960s tested and OK.uploded
    mainboard part number: 715g4197-m01-001-004i
  • esinior
    Smd code to part number
    by esinior
    Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
    I've attached pics of this part
    Thanks...
    08-20-2024, 02:50 AM
  • Yanleb
    Panasonic part number in service manuals
    by Yanleb
    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
    For an example, look at the attached PDF.
    Do you have a way to cross reference the Panasonic part number with the actual part number?
    Thanks....
    07-03-2023, 08:16 PM
  • sikocan
    Lenovo X1 Carbon 9th Gen Black Screen
    by sikocan
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    06-24-2025, 09:01 PM
  • Devonavar
    Vizio M43-C1 - How closely do I need to match the mainboard number?
    by Devonavar
    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
    So, I've ruled out the PSU for now.
    The reboot loop...
    08-14-2022, 08:46 PM
  • Mdink
    Schematic diagram for clevo w65jo and board part-number 6-71-w65j0-d01
    by Mdink
    Hello, I need help me with schematic diagram for clevo w65j0 and part number 6-71-w65j0-d01.
    07-10-2025, 11:35 AM
