monitor cable faulty
  • gustie
    • Dec 2008
    • 76
    got a free LCD screen given to me from freecycle
    it works but the cable that plugs into my graphics card has internal damage so the colours are skew - it displays in pink but if you wiggle the wire it will fluctuate colours
    is this easy to fix ? replace the cable? i guess it would involve soldering - if i could get a similar cable.........
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: monitor cable faulty
    [I'm assuming one end is permanently attached to monitor.]
    You can get connectors for the end but they are a pain in the butt to install.
    Probably easier to replace the whole cable back to the solder joints on the PCB board.
    Can scavenge one from a dead monitor or clip one end off a VGA-VGA cable.
    Make sure you leave the end with the correct pin male/female configuration.
    - As in don't cut off the end you need if they are different....
    Mann-Made Global Warming.
    - Dr Seuss
    • gustie
      • Dec 2008
      • 76
      yeah the cable is fixed
      i think the cable is broken at the pc plug end or near the rear of monitor
      aint looked at it for a while - it looks like some one has twisted the cable round and round till its twisted and snapped an internal wire or something
      looks like i should go buy a soldering iron!!
      anyone recommend summat CHEAPish but WORTHY of this and doing a decent job on cap replacing?
      thanks
      TICTAC 619XT Bios
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        A generic 30 or 40 watt should do fine for that.
        [Kind of depends on what there is for soldering in there.]
        I got a generic 60 watt (ECG brand) at Fry's a while back for $8.99. [Not even on sale.]
        It's a cheapie but not total junk. At least the handle is insulated.
        Make sure to get some fluxed solder braid to help with removing the old solder.
        Also solder around .022" diameter. (or .032 might be okay.)
        Too big is harder to use on smaller joints.
        If too small then you just feed it faster.
        - Dr Seuss
        • paparazzo79
          what's faulty monitor,cable,or graphics card on wake from sleep?
          by paparazzo79
          Hi friends.
          I was having this issue since I purchased the monitor,but then again it maybe works like that.
          Back at that time I didn't want to RMA the monitor due to covid and waiting toooo long for return.
          So the monitor CJG50 32 " from Samsung has 3 inputs (DP+2HDMI).
          I have 3 PCs hooked up to all 3 ports.
          But only over displayport input monitor wakes up from standby and I do get picture.
          Over both HDMI I had to manually select the source over monitor settings (OSD settings built into monitor).
          Input source was selected to automatic by default in...
          09-03-2021, 10:29 AM
        • Borse2008
          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
          by Borse2008
          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
          • There’s
          Today, 04:55 AM
          by momaka
          03-15-2023, 10:17 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • alfredomfr1
          HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
          by alfredomfr1
          12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
          06-04-2025, 10:23 AM
