Strange problem with lcd monitor, help please
  • xinyuanZ
    • Dec 2008
    I have a 20" inch lcd monitor made by DCLCD. it only use about one year, the problem is: after monitor run about 10-15 minutes , it turn to black about one second then come back in every 4-5 minute.
    any help would appreciate!
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Strange problem with lcd monitor, help please
    Turns off totally, screen goes black and led stays green, or screen black and ambar/flashing power led?
    There are really smart guys around here, but you need to give more data on the problem for them to figure out what's going on.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • Askic
      Problem with monitor DS-D5022QE-B
      by Askic
      Hello to all,
      I have a problem with monitor that is delivered together with CCTV system.
      The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
      I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
      05-31-2023, 03:14 AM
    • CptChronic
      Samsung LU32J590UQUXEN Monitor display problem
      by CptChronic
      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
      04-24-2023, 04:33 PM
    • tmhobadcap
      LG 24MP56HQ-P Monitor Backlight problem?
      by tmhobadcap
      I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
      Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
      I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
      10-13-2021, 01:52 PM
    • tmhobadcap
      by tmhobadcap
      10-12-2021, 01:43 PM
    • Phil Stasik
      Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
      by Phil Stasik
      Pioneer Pro-FHD1 Elite. Failure to power on.
      I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
      We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
      01-19-2023, 01:22 AM
