SyncMaster 203b
  • Logistics
    • Apr 2007
    • 721
    SyncMaster 203b
    I finally decide to fix up my Paps' system and the LCD decides it wants to go bad. What will happen is the image will start flickering really dark and sometimes go away completely so that all I"m left with is a white screen; sometimes half the screen is brighter than the other half, and sometimes it just goes black, but sometimes the image comes back nice and bright. Figures it would be right after I "had to go and touch it."
    Is it a caps thing or maybe the backlight is going bad?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
  • Wizard
    • Mar 2008
    • 2296
    Re: SyncMaster 203b
    Check your manufacture date on back of LCD if it is less than 3 years and paps have receipt for it, have it repaired.
    Cheers, Wizard
    • Logistics
      • Apr 2007
      • 721
      Re: SyncMaster 203b
      I'm sure it was less than 3 years, but when we got it it was the last one, the floor model.
      • Wizard
        • Mar 2008
        • 2296
        Re: SyncMaster 203b
        Still applies, no matter, the receipt is your final say on 3 year warranty date.
        Get crackin' on the warranty proces.
        Cheers, Wizard
        • Raulnn
          TD Systems K50DLG12US half black and half white screen
          by Raulnn
          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
          01-20-2024, 04:49 PM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • valvashon
          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
          by valvashon
          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
          11-24-2024, 12:08 PM
        • soopacrucial
          by soopacrucial
          Hi folks,
          10-29-2024, 02:40 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
