Samsung Syncmaster 173s Input signal problem
+ More Options
Posts
  • EGuevarae
    • Nov 2008
    • 1336
    Hi. I'm new to this forum (posting, I've been reading it for like two months so far, until I feel comfortable with a little knowledge and a soldering iron).
    I have a Samsung 173s that turns on, lights the screen, and then displays the "No signal cable" roaming message on screen. It can stay that way for hours. As soon as I connect a VGA cable to the D-sub input, the screen goes black, and the power led starts blinking. If I remove the VGA cable, it again displays the message of no signal. I opened it and removed the two lamps (2 tubes each one, used them on a ToteVision 18" that had a bad inverter, which was replaced with one from a VE500), so right now it has no lamps installed. The monitor is in good condition, and being 17", I don't want to use it for parts if it can be fixed. I don't have a camera right now, but I will in a couple of days. The boards seem good on visual inspection, but I don't know much about electronics, so I don't know where to start looking. Any advice would be really appreciated.
    Thanks in advance.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Samsung Syncmaster 173s Input signal problem
    I'm no wiz kid with these (not compared to some other members) but here is the basic idea.
    There are 3 main circuits:
    - Power supply
    - Back light
    - Video
    Power supply may be 100% built in or partly a power brick (AC adapter).
    - At least part of this is working as your back light works.
    But that doesn't mean all it's outputs are working.
    Back light is the inverter circuit and the the back light tubes.
    - Probably not where your trouble is. No back light gives a blank/black screen.
    Video section.
    - Most likely the problem (either itself or it's not getting power from power section).
    This section takes signal from the video card and converts it for display on the screen.
    This section also sends a signal to the PC from it's own firmware identifying it's own settings so the PC can automatically adjust to the correct output. (aka Plug n Play)
    I would first try a different VGA cable and check the pins in the connectors on the cables, PC, and screen. Cables go bad and sometimes pins get bent or even break off.
    Next look closely at the caps and tell us what they are.
    Samsung has been know to use poor caps.
    Trying to fix other things with bad caps in there can be a huge waste of time.
    Mann-Made Global Warming.
    - Dr Seuss
    • EGuevarae
      • Nov 2008
      • 1336
      The lamps are good. They're working on a ToteVision 18" right now.
      The inverter lights (used to) light them good, because all the screen was lighted and the "no signal" dialog roamed free in all the screen area.
      I have tested with different VGA cables on different computers here (I have some cables and computers here). I normally only messed with software (I'm a programmer) but now I'm starting to get into hardware too, and because of the SW dev, I have 3 or 4 computers around, and the monitor have been tested in all of them (just in case. I used to have a CRT which only worked with nVidia cards... weird).
      I now have a camera but it is not that good. I'll post pictures of the boards.
      I got this monitor for $30dlls hoping that it can be repaired (the ToteVision was ..), and will really love to use it instead of the CRT in my test bench.
      • GeForce GT1050
      • EGuevarae
        • Nov 2008
        • 1336
        The power board is not on a brick, is inside the monitor, in the same board as the inverter circuit (the LCD has just two boards on the inside : the video board and the PS/Inverter board). Pics are very crappy, so I'm not going to post them (very blurry).
        But here is the list of caps:
        1 - 25v 470mf Sam Young LXZ
        1 - 400v 100mf SamWha RD 105C
        4 - 16v 100mf CapXon KM 105c
        1 - 50v 22mf Sam Young
        The 400v,25v and 50v are right next to the AC input, and the 4 16v are after the transformer BN26-00012A, which I figure is the one that transforms the Voltage to 12v (just guessing). None of them looks strange, bulging or blown. The voltages from the power board to the video board are 12v (2), 5v (2), 3 GND and two that I think they are the return for the BLON (5v) and Dimmer/Bright (2~2.5v, and when I check that pin, as soon as I touch ground the lamp shines more than normal, and when I take the probes out, it return to normal).
        No visible signs of overheating on top or bottom. As soon as the VGA cable is connected between the VGA card and the monitor, the lamps shut off, the power led blinks (green) and no image.The only change in the signals between the boards is the line that I suspect is the BLON : no voltage when the VGA cable is connected (I assume that's why the lamps shut off). This happens even when I connect the cable to a VGA card alone (not in a computer).
        Should I apply 5v to the BLON pin to see what happen?
        • GeForce GT1050
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I have no idea.
          What I would do now is trace circuits and work out a schematic.
          Injecting a voltage when you aren't sure what's going on doesn't sound like a great idea in general.
          Yup, those caps are junk.....
          SamWha is crap for low ESR applications but this is on AC input and not likely to be a problem. If it was bad you probably wouldn't be getting any life at all out of the thing.
          Sam Young is Korean based and at least loosely affiliated with Chemicon.
          I think they make caps for each other but those marked as/branded Chemicon are probably built to better standards using Japanese aluminum. (Or at least I like to think so...)
          25v 470mf Sam Young LXZ - 10x16mm - Ripple=1050, ESR=0.068
          Panasonic FC, Digikey PN: P10275-ND .. Ripple=1050, ESR=0.068
          50v 22mf Sam Young - [What series? Can't look up.]
          Panasonic FC should be fine here anyway.
          Panasonic FC, Digikey PN: P10318-ND
          CapXon seem to do okay in power supplies but not in other low ESR applications. These aren't low ESR rated caps though.
          - 6.3x11mm - Ripple=130, [GP cap, ESR not listed]
          - 5x11mm - Ripple=115, [GP cap, ESR not listed]
          If 6.3x11mm: Panasonic FC, Digikey PN: P11198-ND .. Ripple=290
          If 5x11mm: Nichicon VZ, Digikey PN: 493-1283-ND .. Ripple=115
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            OH, AND:
            Monitors are not Hot-Swap.
            You need to turn them and the PC off BEFORE you plug VGA cables in or unplug them.
            - Dr Seuss
            • EGuevarae
              • Nov 2008
              • 1336
              Well. I suppose you are right about the voltage, but I was (and still I am) sure it was the BLON for the lamp. And it was/is. But the result was the same : no data on screen, blinking (green) led and lamps on (the only change).
              On the Video board (the other one in there), I checked four surface mounted caps (2 are 47 16v and 2 are 100 16v. I assume the 47 and 100 are mf) and one of the two 100 16v showed no resistance (as if it was a fuse) and the other did not.The one in short was right before the output of the BLON, so I removed it and put one normal cap, but the same result showed up. Then I removed the other 100 16v and swapped them, putting one in the other's place and viceversa. Same result. I noticed that the one that was "short" had one loose pin
              Now the lamps are always on, even if I turn off the monitor using the power button (I did not leave the temp voltage bridge used to test, and I'm sure the pins are not in short). I tried doing all of this with and without the LCD panel attached with the ribbon cable to the video board, and same result. I am pretty sure now that the problem is in the video board section. I browsed in www_fixya_com, and someone suggested that I pushed down the chip (eeprom, I think), and it was kind of loose, but no change. Now I removed completely the video board to check it more in detail, but I think that it is dead.
              I have a question : can you replace the surface mount caps with thru hole ones? or what is the difference?
              And thanks for the advise so far.
              • GeForce GT1050
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I had a viewsonic with the blinking green light problem and it only actually needed one cap. It would probably be the same (functionally) as your 25v 470mf. It was an output filter cap between the PSU section and the video section.
                - Mine was obvious though because it was bloated.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  >> replace the surface mount caps <<
                  Not easily but I've seen people do it.
                  Functionally the caps are no different if the specs are the same.
                  If you try that make sure you don't damage the bung (plug) in the bottom of the cap when you are bending leads around or it will leak. Best to grab lead with a mini-needle-nose pliers placed right next to the bung and bend against the pliers.
                  Also don't short leads to sides of can.
                  - Dr Seuss
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    I'll change the 25v cap and try to change the surface mount ones. I think it is dead already and I'm only counting with the rest of the components for future use, so nothing will be lost.
                    • GeForce GT1050
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i see the guts of these in industrial touchscreens and the sm lytics dry out in a few years.replace them ALL.
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        The SM were changed yesterday but same result. One of them was bad anyway (a loose leg). I have just changed the 25v 470mf Sam Young for a Rubycon, and there was image (dim because the original lamps were used in another monitor and I installed two lamps for the inverter to work : one inside the panel , and one that doe snot fit is outside. Lit but outside) .
                        Now the lamps don't turn off (since I changed the SM on the video board). The line that I think (now I'm sure) is BLON before the change didn't have any voltage with the monitor in off mode, and now it has between 1.9 and 2.3v, which causes the lamps to ignite.
                        Any idea? This started to happen when the SM were changed.
                        • GeForce GT1050
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          So far the monitor still works like a dream.....just the lamps never turn off. If I turn off the monitor via the on/off button, the green led turns off and the image fades to end up in an all white screen. I have to disconnect the power cable to shut it off. Well, I think it's better that way than the way I got it. In the end, it was only the 25v 470mf output cap that PCBONEZ mentioned. The other two changed caps didn't do anything (better, I mean..), except that maybe I shorted one and that's why the voltage leaks and the lamps are always on.
                          Thanks for all your help.
                          • GeForce GT1050
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            I just noted that between the 2 pins of one of the 150mf caps I changed (that when I followed the track, ended up in the pin that I am sure is the 5v BLON signal) there's always 4.9~5.0v. The other one that I changed does not (this other one has only voltage when the LCD Panel turns on, and goes to one of the pins from Video Board to the LCD). I think this is the reason for the lamps to be always lit.
                            • GeForce GT1050
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Well, one of the lamps (lower pair) blow... literally. With bang and all. I gave up and used the screen to fix a Dell E171FP that came to me with an all-white screen. The monitor is now working perfectly : Dell's original circuitry (with replaced CapXons) and lamps (all four) and Samsung 173s LCD panel.
                              I'll just store the parts of the 173s to be used in the future. I couldn't win this one ....
                              • GeForce GT1050
                              • Bobdee
                                • Jun 2008
                                • 461
                                Hello eguevarae
                                Enjoyed the Thread with all your Info, and Perceiverence, and enthusiasm,
                                AS with the contributions from the others,
                                THXs bob
                                (edit) sorry cancell edit
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  Wow. Bang! :O
                                  Well, there is a bulletin on that 173 series that there is a ferrite SMD inductor next to the power plug on the green mainboard, take this out and bridge this with little piece of wire and solder. Then replace many SMD electrolytic capacitors.
                                  Cheers, Wizard
                                    09-07-2024, 05:50 AM
                                  • soopacrucial
                                    Samsung Syncmaster 740BF repair
                                    by soopacrucial
                                    Hi folks,
                                    I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                    Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                    10-29-2024, 02:40 PM
                                  • Ellos
                                    Samsung s21 sim recognized but no signal
                                    by Ellos
                                    I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                    I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                    From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                    I think I've located the SOC that...
                                    06-27-2025, 01:31 AM
                                  • Xristakis795
                                    samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
                                    by Xristakis795
                                    hi to all
                                    i have the above model ue40d5003
                                    the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
                                    when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
                                    when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
                                    Can you tell me from your experience...
                                    02-09-2023, 03:17 PM
                                    09-06-2024, 11:40 PM
